being very safe while loading or unloading
Discussion in 'Experienced Truckers' Advice' started by kaybea, Jul 4, 2015.
  1. kaybea
    kaybea Light Load Member
    52
    121
    Jul 12, 2014
    I don't get excited over whatever policies a shipper or receiver has for drivers when being loaded or unloaded. Some places you just back in and then you take a nap or whatever until they knock on the door and say you're good to go. Others have the driver come inside, etc. I was at a place and did something I haven't seen before. They had me disconnect the air lines then they put the lock out tag out on the trailer. And the place had a dock lock and I had to chock the tires.
    I don't mind, nothing wrong with being safe, but I'm not sure if this is necessary. Has there been a problem with drivers pulling out of docks before they were supposed to?
  3. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    There have been a couple videos posted on this site that show a driver pulling out with a forklift in the trailer. So as strange as it may seem i guess it happens.
  4. marineman227
    marineman227 Dock Waterer
    600
    796
    Jan 26, 2008
    Neenah, WI
    I've had quite a few like this. Surprised you haven't seen it before. I've had a couple that were the same dock lock, chocks, airline lock and they make you drop the trailer and pull a few feet in front of it
  5. HorseShoe
    HorseShoe Road Train Member
    1,494
    2,779
    Jun 29, 2015
    More paranoia from corporate lawyers
    Hammer166 and G.Anthony Thank this.
  6. MJ1657
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    I've had to take my air line off a couple times with a flatbed.
  7. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Me too, when I switched trailers.
    truckon, Hammer166 and HorseShoe Thank this.
  8. snowwy
    snowwy Road Train Member
    20,597
    13,318
    Jul 6, 2009
    not only that, MJ. but they put a lock on the glad hand and take your ignition key.
    it could be about corporate lawyers. but that shouldn't be our concern.
    human safety should be our concern.
    BrenYoda883 and MJ1657 Thank this.
  9. passingthru69
    Was at a rig builder this week. When out of the trk. you shut it off or chock your wheels. When moving the trk. forward or backwards
    you had to blow the air horn.
    Reason is they had a worker get killed 2 years ago by a trk. backing up.
    This place is busy with people and equipment moving at all times
  10. xsetra
    xsetra Road Train Member
    5,174
    7,111
    Aug 21, 2011
    I had jersey barrier put in front of truck while getting loaded. Open deck, side loading.
  11. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    I had 1 with some high tech wheel choke, if you don't put the choke close enough they can't open the door. I usually give a small gap like half an ich so the tire don't get stuck on it while unloading or loading. It came with a bar so drivers can push the choke out since it does get stuck
