Best way to remove spinning bolt off bumper on FLD?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by magellan, Sep 13, 2020.
  1. magellan
    magellan Light Load Member
    65
    14
    Feb 8, 2016
    I got rear ended awhile back and am trying to replace this bumper. I removed all bolts, except 1. This one just keeps spinning and I can't get a wrench behind it due to the location. It appears it's a 3/4. I may try a longer wrench tomorrow, but want to pick your brains before I get started.
  3. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Small grinder with cutting disk.
    Make several cuts each , time till you hit the washer..
    Rinse and repeat till head off the bolt is smaller then the inside off the washer.
  4. 062
    062 Road Train Member
    6,275
    33,779
    Oct 20, 2013
    Possibly use a pry bar or long screwdriver to trap the nut, then zap it with a impact.
    magellan, Rideandrepair and D.Tibbitt Thank this.
  5. '88K100
    '88K100 Road Train Member
    1,400
    3,211
    Aug 23, 2020
    Die grinder to cut head off.
    magellan and Rideandrepair Thank this.
  6. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    Use a high speed impact
    Rideandrepair Thanks this.
  7. Rideandrepair
    17,424
    56,527
    Aug 8, 2015
    I’ve used a big screwdriver more than once, jammed in against the nut. Be sure to use SS nuts bolts and washers, when reassembling. A flat washer between the bumper and bracket, also. To keep from dimpling they new bumper, when it’s tightened up.
    magellan, 062 and daf105paccar Thank this.
  8. Goodysnap
    Goodysnap Road Train Member
    3,744
    9,105
    Jul 12, 2017
    The stainless is part of problem. Stainless on stainless bolt/nut almost always get galled togther especially when running them together with an impact wrench at high speed. You need a lubricant or antisieze when installing stainless hardware. If you can get away with it a standard zinc or nickel coated nut will work much better on stainless bolt for ease of removal the next time. Assembling by hand will also keep the heat to a minimum which is what can cause the threads to lock together.
  9. Rideandrepair
    17,424
    56,527
    Aug 8, 2015
    That makes sense, a regular nut, I used all stainless on my steps. Once they’re tight, that’s it. Have to snap them to get off, first time I’d ever heard of SS galling together. And it happened immediately, I torqued them a lot, couldn’t get them off.
    magellan and Goodysnap Thank this.
  10. blairandgretchen
    13,609
    73,951
    Dec 9, 2011
    South west Missouri
