Blew my stack...
Discussion in 'Ask An Owner Operator' started by hindsy, Jan 13, 2018.
  1. hindsy
    hindsy Road Train Member
    1,489
    518
    Mar 23, 2010
    USA
    please don’t judge me... or go ahead but don’t share your judgement. Lol
    Recently I managed to have an oops while delivering steel tube.
    Little background first. Went inside office staff says “just pull under...” (this here starts the trouble!) “...the hoist beam right out there and the guy will be out to get you unloaded.”
    So, I do as they say and well the steel beam is a little lower than I anticipated. It rubbed my stacks, but once I heard the noise of it I was already beyond PONT (point of no return) It rubbed a bit more than just a little and bent one stack and removed the other from the lower exhaust. Now I tried to fit the stack back in, but failed. It flew out on the road. I recovered it and had it put back on again where it days later flew off again and ended up in a gully along I75. Now no one was hit or involved and this leads to my question. They are side stacks on a Pete.
    Is the upper stack a DOT infraction if it’s missing?
    Am I risking any issues by running till I can replace it myself?
    Do I need to repair this immediately?
    Length of the stack, how important is this? I may just order both new and replace them at the same time.
    Any one got recommendations on where I can get a couple 5” curved chrome 36-48” stacks?
    Thanks
  3. stayinback
    stayinback Road Train Member
    3,911
    8,256
    Jan 24, 2014
    chicago,il
    So you're driving down the road and your "stack" popped off and bounced into the gulch?
    lol..........What would make it even more funny is if you are driving a Pete 379 or KW W9
    On a serious note- It probably kept popping out because you bent the Muffler Flange or Pipe Flange (whichever) .Yes,An easy Fix you do yourself if you know anything about repairs.
    If you don't,Go to a shop so they can laugh at you
    Dave_in_AZ and hindsy Thank this.
  4. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    Don't feel too bad. I bought my truck with a dinged exhaust tip on the passenger side, and the first time I loaded at a cement plant in Indiana, I clipped the driver's side on a catwalk and made it a matching pair. Luckily, I didn't tear anything off...so when I got home, I pulled the stacks out of the mufflers, used a ball peen hammer to round them out and reshape the tips, then lopped a good 2' off the bottom of them. Now, they'll clear anything overhead structure above 10'.
    hindsy Thanks this.
  5. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    Replace both of the stacks, and make them shorter. Problem solved.
    Lepton1 and hindsy Thank this.
  6. hindsy
    1,489
    518
    Mar 23, 2010
    USA
    Cheaper too...
    Justrucking2 Thanks this.
  7. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Just get a set thats a bit taller than top of bunk and keep on pulling under with no more prob.
    hindsy Thanks this.
  8. RoadRooster
    RoadRooster Road Train Member
    4,121
    6,709
    May 10, 2015
    Fort Myers, Florida
    Sitting here... arms folded... glasses down towards the end of my nose... looking at the screen over the top of my glasses...
    That's me being judgmental but keeping it to myself...
    Seriously dude, clever title... I was expecting a whole different direction.
    hindsy Thanks this.
  9. snowwy
    snowwy Road Train Member
    20,590
    13,308
    Jul 6, 2009
    I've had my stack twist around. Even tip a little.
    Never had a stack blow, though.
    hindsy Thanks this.
  10. Chinatown
    Chinatown Road Train Member
    76,744
    178,652
    Aug 28, 2011
    Henderson, NV & Orient
    Weed burner exhausts will solve the problem.
    @blairandgretchen mentioned putting weed burner exhaust on his truck; if he did, maybe will post a picture.
    hindsy Thanks this.
  11. xsetra
    xsetra Road Train Member
    5,161
    7,092
    Aug 21, 2011
    I don't think you are in violation of any regulations.
    Exhaust can't leak under cab. Doesn't say where it has to terminate.
    Put a new band clamp on, to hold together.
    Good luck
    hindsy Thanks this.
