Blown head question
Discussion in 'Ask An Owner Operator' started by Luke700, Oct 11, 2021.
  1. Luke700
    Luke700 Light Load Member
    57
    26
    Oct 14, 2019
    I know my head is blown but I had plans to do an overhaul just not right now. How long can I run it for? Oil level is the same it’s not rising. No smoke is blowing. Truck has . I just have pressure in my coolant tank. And I catch and refill it with old coolant bottle attached to the expansion hose after it waste coolant into it.
  3. Judge
    87,806
    hard to say how long, depends I guess on terrain, hills/mountains, could go a week, could go a month.
    I just spent 23k on inframe a few months ago on isx Cummins which had a blown head gasket
    ProfessionalNoticer Thanks this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    I went six months on a Mercedes MBE4000. But it had external coolant leaks around heads.
    shatteredsquare Thanks this.
  5. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Same here. 25k on a CAT.
    Judge Thanks this.
  6. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    I ran mine while it puked for almost a year. It started off just a few drops but I didn't really start worrying about it until my undercarriage and suspension started to turn white from the coolant. I kept a very close eye on all fluids and rolled the dice. Are you a gambling man?
  7. Luke700
    57
    26
    Oct 14, 2019
    Haha defiantly a gambling man but I’m a terrible gambler trying to quit hopefully this truck convince me to . This my last gamble
  8. zinita17601
    zinita17601 Road Train Member
    1,318
    1,603
    Aug 19, 2010
    lancaster pa
    Why not just replace the headgasket?
  9. Planet310
    Planet310 Bobtail Member
    5
    Oct 11, 2021
  10. Planet310
    5
    Oct 11, 2021
    It is likely the head gasket. That isn't only possibility tho. Air compressor head failure can add pressure to the coolant system. Need to test for combustion gas contamination. As far as how long to limp around. No way to tell. How lucky are you? ;)
    AModelCat Thanks this.
  11. haycarter
    haycarter Road Train Member
    1,920
    5,317
    Jun 9, 2012
    Australia
    Because, There's ALWAYS a reason the Head Gasket Blew, & replacing the gasket will not cure the Problem.. just prolong the Agony..
    TallJoe, Elroythekid and Snailexpress Thank this.
