Bobtailing to orientation
Discussion in 'Trucking Industry Regulations' started by Stacie, May 18, 2014.
  1. Stacie
    Stacie Bobtail Member
    30
    4
    Mar 10, 2014
    Md
    Must you fill out a log if you are bobtailing to oreantation??
  3. scottied67
    scottied67 Road Train Member
    10,826
    12,673
    Mar 14, 2010
    california norte
    When the statute of limitations expires, I have a great 'bobtailing to orientation' story to tell. Short answer, yes I did log Driving to orientation. the rest is an interesting story for another day.
  4. ingedavi
    ingedavi Light Load Member
    53
    18
    Jan 1, 2008
    Eau Claire, WI
    If you drive it, yes.
  5. SpiritWolf
    SpiritWolf Light Load Member
    192
    118
    Jul 10, 2012
    North Highlands CA
    Montana DOT officers told me as long as you are not on a "dispatched" run, then there is no need to log anything.
    But then again Washinton told me all use of the truck had to be logged.
    If anything, be safe, and do a log. Mark it as "off duty, personal use".
    EDIT TO ADD...
    Im not a legal expert, so don't quote me on that. But it is what I do... hopefully Im doing it right.
  6. 70s_driver
    70s_driver Medium Load Member
    611
    358
    May 4, 2014
    I would log it on duty driving just to be on the safe side until you get to orientation, then ask them how you should log it. (That would protect you just in case you get D.O.Td somewhere before you get to orientation). If you log it on duty they may give you a hard time and say it should be in the driving grid since you are driving a CMV. There are some out there that would mess with you on it. If you're doing what you say you are doing on your log, they wouldn't be able to gig you for it as long as you're not otherwise breaking the law or HOS.
    kimbosa Thanks this.
  7. freightrunner
    freightrunner Heavy Load Member
    722
    182
    Mar 25, 2012
    Georgia
  8. Gordon A
    Gordon A Medium Load Member
    384
    345
    Jul 22, 2013
    Log it, You can always tear it out and do an off duty log later.. . I talked to a OK HP and he told me that MOST of the bob tails he stops have bad logs or no logs at all. Just a heads up. Better safe than sorry. Be kind of rough to go to orientation with a logging ticket now wouldn't it? Just saying better safe than sorry.
  9. Stacie
    30
    4
    Mar 10, 2014
    Md
    Thanks everyone i plan to log it but i was jst wondering if i could get away with logging off duty or not
  10. freightrunner
    722
    182
    Mar 25, 2012
    Georgia
    You're not under dispatch so I don't see why you can't but if you have to pass scales just log it to be on the safe side.
  11. Scalemaster
    Scalemaster Heavy Load Member
    808
    1,717
    Mar 13, 2011
    Midwest
    If it is a CMV and you are driving it - Yes, you need to log that as driving time.
