Bridge Laws - Where to set trailer tandems? How do you figure it out?
Discussion in 'Questions From New Drivers' started by FreightlinerGuy, Jul 2, 2015.
  1. FreightlinerGuy
    FreightlinerGuy Medium Load Member
    472
    225
    Apr 20, 2008
    Great Lakes, USA
    Hey fellas,
    I haven't had to pull any 53' trailers in quite a long time especially not had to move the tandems. I know how to move the tandems, but how do you figure out where to move them to length wise? I know I read that its typically the fourth panel on the trailers but what is a better way to figure it out when trailers don't have the markings, etc..
    Thanks
    ac120 Thanks this.
  3. DUNE-T
    DUNE-T Road Train Member
    7,014
    17,069
    May 10, 2015
    Detroit, MI
    Under 30k I just leave 7 holes from the front. Over 30 I slide tandems based on weight and I try not to haul over 42
  4. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    The standard king pin is set 3' back from the front edge of the trailer. For a 53' trailer, that leaves 50' behind the king pin. Depending on what state you are working in or through, is how you set the distance for axle to king pin. [check in a truckers atlas for each state requirements] Example; for CA, 40' from king pin to center of rear axle, measure 10' from the rear most point on the trailer, this spot will be where the maximum length the tandems can be back. Anything in front of that 40' spot is OK.
    Pups and some container chasis do not follow this 3' rule on king pin placement.
    ac120, FreightlinerGuy and w.h.o Thank this.
  5. Kamikaze Pilot
    Kamikaze Pilot Bobtail Member
    4
    Sep 5, 2013
    Most bridge laws are anywhere from 41 thru 45 feet. This is measured from the centerline of the king pin to the center line of the front axel on the trailer. The standard Rand McNally truck map book has bridge laws for all states including those for spread tandems, doubles, triples and b-trains. Most state scale houses have a length gauge when you roll across the scales. Most states are starting to pay more attention to trailer length especially in larger cities.
    NavigatorWife and bobtrucks2204 Thank this.
  6. FreightlinerGuy
    472
    225
    Apr 20, 2008
    Great Lakes, USA
    Thanks! This is the method I remember using awhile ago.. With this method the rear axle must be inside where you measure the 10' or the center of the tandems at the inside 10' mark?
    otherhalftw Thanks this.
  7. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    The center of the last axle
    FreightlinerGuy Thanks this.
  8. ncmickey
    ncmickey Road Train Member
    3,852
    7,253
    Jun 21, 2013
    Durham NC
    Some states are to the center of the axle group.
    Busasamurai and FreightlinerGuy Thank this.
  9. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    States are different on which place the measurement concerns; i.e. CA center of rear axle. As was stated, center of axle group and some can be center of forward.
    Check the truckers atlas it has the measure and place for each state.
  10. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    I set mine to the 41' center of the tandems as default. Unless it's loaded backasswards that usually works. Legal pretty much everywhere except California and provides the best compromise between maneuverability and backing ease. The farther the tandems are back the easier it is to control your tailswing when backing into a spot. Of course that goes out the window at truckstops like the Love's in Tacoma....
  11. MACK E-6
    49,627
    233,887
    Longer wheelbase also makes for a smoother ride.
    The tailswing issue is a concept that lost on most of my co-workers. Just about every 48 footer we have with that's commonly ran with the tandem slid all the way up has damage to the sides of it near the back.
