Bulkhead for pipe loads?
Discussion in 'Flatbed Trucking Forum' started by Gunner75, Aug 5, 2016.
  1. Gunner75
    Gunner75 Road Train Member
    5,701
    9,073
    Mar 17, 2014
    Jackson Center Ohio
    Ok, so i loaded or with this three tier load of pipe today. And according to my safety manager, it's required to have a bulkhead. I fail to see the reason for a bulkhead. It's not going to prevent the top two tiers from sliding. I have my belly straps on the bottom and middle tiers, and straps across the top as well as 2 2" straps used for banding the pipe together. All this is normal for my pipe loads, but the bulkhead? What in the hell for? Just seems pointless
  3. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    No point. Just like your safety manager. Maybe he thought it was just 1 tier high
  4. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,755
    Sep 20, 2014
    Required by whom? By him out does he think it is legally required?
  5. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    If you have a headache rack you are good to go. Many a pipe load that is longer than the trailer will hang over the back and the front of the trailer. A bulkhead would get in the way and may cause you to be over length (depending on the state). Those that specialize in long pipe loads have extended catwalks and NO bulkhead.
  6. Zeviander
    Zeviander Road Train Member
    4,887
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    Company policy says put it on, just put it on. It'll look stupid but you won't hear from him about it again.
    I picked up a four tier steel load a couple months back. With dunnage and all the bundles, it was close to 5 feet tall on the trailer. Had to poly and tarp outside, by myself. Still put the bulkhead on in front because when we pick up from this mill, we are supposed to put one on. Normally, the loads barely make it one foot off the deck.
    *shrugs*
    It's just one more piece of securement. And stupidly enough, my company policy also is put the bulkhead out in front of the load, rather than tight up against it... as the "safety manager" thinks the dunnage is supposed to break and the single 5/16" chain is supposed to "catch" 45,000 pounds of steel. I still shake my head at that one when it comes up.
    If I'm pulling it, that bulkhead goes up against the steel. Won't pull a load of steel (that's not formed tube) without one. A single 9000 lb bundle, let alone 5, is not something I want to play around with.
    Not a word has been said to me about it yet.
    Highway Sailor and Lepton1 Thank this.
  7. Zeviander
    4,887
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    Don't trust a headache rack to stop steel. Trust in one's securement. My rule of thumb for steel is:
    "What are the DOT minimums? Double it and add 2-3."
  8. Highway Sailor
    Highway Sailor Road Train Member
    1,328
    1,659
    Nov 23, 2011
    Erie,Pa.
    I would build a bulkhead if I had room on the deck for it. That's what they want, that's what they get. It's their truck, it's their rules. One time I had a 2 tier load of various sized steel pipe from TT in NJ that I just did not like for forward movement. What I did was to take a 4X4 dunnage and put inside the two outside pipes having them stick out about 8 inches. Then I took a chain and laid over the top of the dunnage going across the front of all the pipe in between. Put a binder on it and all was good. Now because the pipe overhung the front of the trailer this worked well for both tiers.
    Lepton1 Thanks this.
  9. Lepton1
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    Amen.
    Edited to add: A bulkhead is just to make it look purdy.
    Zeviander Thanks this.
  10. Lepton1
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    I like that idea.
  11. MJ1657
    MJ1657 Road Train Member
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    Safety directors are the reason for alot of confusion on this site. They tell their drivers goofy things and drivers take it that it is the law.
    This just a general statement it's not directed at you Gunner.
