Bumper pull?
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by Yelsew, Jan 25, 2019.
  1. Yelsew
    Yelsew Bobtail Member
    16
    4
    Dec 17, 2018
    Is it safe to haul 2 cars in a 8.5×34 enclosed bumper pull trailer?
  3. Numb
    Numb Crusty Curmudgeon
    3,995
    9,068
    Jan 30, 2012
    Charlotte, N.Carolina
    bumper pull?? what is that exactly?
  4. BCV
    BCV Light Load Member
    233
    436
    May 26, 2018
    Ball and hitch receiver off the bumper.
  5. Yelsew
    16
    4
    Dec 17, 2018
    Lol I'm a newb. Tag along trailer. Not a gooseneck.
  6. BCV
    233
    436
    May 26, 2018
    What are you pulling it with?
    Are you asking if a car hauling trailer that was made to be pulled from a bumper is safe to pull from a bumper?
  7. Yelsew
    16
    4
    Dec 17, 2018
    Yes but for commercial use.
  8. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Refer to car manufacturer and load. have seen lady pulling 43ft RV and big boat behind RV.
    Yelsew Thanks this.
  9. GypsyWanderlust
    GypsyWanderlust Medium Load Member
    386
    568
    Jan 1, 2018
    You need to know what the tow rating is on the truck and how much your trailer and load will weigh. You might want to scour the forum for posts on hauling with pickups. Most are not designed for heavy commercial use but will still cost plenty to operate.
    Yelsew Thanks this.
  10. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,132
    Mar 5, 2016
    White County, Arkansas
    Your truck should have had a paper inside the glove compartment like my last one did.
    Height of center of gravity above pickup bed, maximum Class Three hitch weight (Expressed in maximum hundreds of pounds you could put from the tongue of the trailer onto the truck's bumper hitch ball.) Then you had towing capacity in a few thousands of pounds total including what the cab of the truck had in way of stuff and people plus the weight of any cargo in the bed. Ultimately you could not be above a certain total gross combination vehicle weight as well as electric braking among other considerations.
    The hitches I use go to the frame near the rear axle with many bolts. Never off the bumper itself. It will just get ripped off towing say a simple log splitter.
    You would be much better off in a dually with a 5th wheel inside the truck bed for a goose neck or a split level RV type trailer high enough to hook it.
    Yelsew Thanks this.
  11. Numb
    3,995
    9,068
    Jan 30, 2012
    bumper pull in my mind would be the old U-Haul bumper hitch. chained to the bumper.
    you mean a receiver hitch.
    Yelsew Thanks this.
