Bunk heater making a constant clink
Discussion in 'Questions From New Drivers' started by DirtyhandsMcgee, Dec 8, 2017.
  1. DirtyhandsMcgee
    DirtyhandsMcgee Light Load Member
    71
    79
    Oct 30, 2017
    I got a 2016 cascadia and the bunk heater won't stop clinking. It sounds like a hammer hammering down nails. I woke up to it in Montana the other night, shut it off, went back to sleep and then woke up with icicles in my nose. Any idea what this is?
    TravR1 Thanks this.
  3. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    its the little fuel pump by the tank
    TravR1 and DirtyhandsMcgee Thank this.
  4. Thane
    Thane Medium Load Member
    330
    307
    Mar 16, 2017
    Maybe the fuel in the lines and the filter was old and it gelled just in the unit.
  5. Maj. Jackhole
    Maj. Jackhole Heavy Load Member
    807
    4,202
    Mar 19, 2017
    Scottie put up a video of a nifty bunk heater.:)
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,294
    Apr 9, 2009
    Humboldt, Sk
    That’s how the fuel pump works on those. It’s basically a solenoid action pump. My Western Star was real loud, my Cascadia is pretty quiet.
    It’s just a matter of where it is mounted that determines how much noice you experience. Could see about moving it.
  7. supersnackbar
    19,063
    46,864
    Aug 19, 2007
    Your Town, USA
    The colder it is outside, the harder it has to work. Those little plastic fuel lines aren't insulated, so the fuel is harder to move when it gets cold.
  8. Balakov100
    Balakov100 Road Train Member
    3,937
    2,637
    May 10, 2012
    Temple, TX
    Every bunk heater I have used always made a clicking sound.
    Maybe have it looked at but chances are it's normal.
    Get some ear plugs lol.
  9. TravR1
    TravR1 Road Train Member
    3,693
    9,579
    Nov 9, 2017
    TX
    I have been thinking about getting some ear plugs for reasons like that one. But then I’d worry I would not hear someone breaking into my cab or trailer, or someone knocking on my door telling me my trailer is on fire
    BillStep and gillz107 Thank this.
  10. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    If it's putting heat out and clicking that's the fuel metering device. The more fuel it needs the faster it clicks. If there is a failure the unit will shut down and not produce any heat. Therefore it is working correctly. Always manually turn it off and give it a few minutes to shut down before you fire up the big motor in the morning. A voltage drop when starting the big engine often turns off the bunk heater abruptly which over time leads to it filling up with gunk and needs maintenance prematurely.
    You shouldn't need ear plugs for the bunk heater clicking. It should be barely noticeable. Just tune it out same as you would do for reefers or idling trucks or people talking you know any of the sounds that occur in truck stop parking lots.
  11. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
