Buying a fixer upper
Discussion in 'Experienced Truckers' Advice' started by Cheeseburgers, Dec 9, 2015.
  1. Cheeseburgers
    Cheeseburgers Light Load Member
    247
    104
    Oct 15, 2015
    Danielson, Ct
    Im a company driver now and im planning on buying a junk yard dog for under 10k and letting it sit and slowly rebuild it with extra cash from my weekly checks. What are your thoughts.
  3. IronWeasel80
    IronWeasel80 Medium Load Member
    387
    375
    Sep 4, 2015
    Belen, NM
    I would say that you would be better served by setting some money aside in the bank and then buying a newer / lower mileage truck once you have a decent amount of money saved up.
    Otherwise, you could end up sinking large amounts of money into a truck that may have many more problems that what you can initially see when you buy it. A new engine here, transmission here, chasing electrical gremlins for 6 months......stuff like that.
    Lepton1, Marky84 and Ruthless Thank this.
  4. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    Planning on being independent? With a yard jockey truck? -_-
    dca Thanks this.
  5. AModelCat
    158,881
    This is the route I'd go if going into trucking. But I don't think you'll find something decent enough to tinker with for $10k. I'd say shoot for around the $25-30k mark and get a solid starter truck that's not beat into the dirt already. Just to put things into perspective, my project truck I'm working on cost $3k to buy, I've invested $2,500 into it already not including about 40-50 hours of my time and it'll need about $35k in parts just to get it roadworthy.
    truckon Thanks this.
  6. Dave_in_AZ
    386,905
    I've noticed that trucks that sit, just sit even if they worked GREAT when they were parked, for any appreciable length of time seem to develop all manner of problems.
  7. Cheeseburgers
    247
    104
    Oct 15, 2015
    Danielson, Ct
    Thats what im planning on Northern. Id do a full engine rebuild, run all new electrical. Basically a brand new truck that i would know everthing and anything about it.
    Id be using the truck eventually as a work truck hauling dump trailer or low boy work locally.
  8. AModelCat
    158,881
    That's what I'm doing to mine. Except I've got to tear it right down to the rails and start fresh. It was a lot worse than it appeared once I started into it.
  9. Cheeseburgers
    247
    104
    Oct 15, 2015
    Danielson, Ct
    Thats what im planning on doing. Id figure im 26 amd in about 10 years. Or less it should be done completely.
  10. dca
    dca Road Train Member
    6,834
    11,427
    May 31, 2011
    Earth
    my guess is you'll need a comfy padded board to lay across the seats for that period of nap time or a small sleeper.
    could always throw up a hammock
  11. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    Hafta swallow it first...
    mnmover and dca Thank this.
