Buying a new reefer unit for hauling ice cream.
Discussion in 'Refrigerated Trucking Forum' started by ktrucking, Aug 9, 2018.
  1. ktrucking
    ktrucking Bobtail Member
    8
    Looking to buy a new reefer unit looking for the right model to buy will be transporting ice cream
  3. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    You also need to focus just as much on the trailer specs. You need to probably avoid used trailers, too
    There are “ice cream specs” for trailers apart from the unit.
    magoo68 and DTP Thank this.
  4. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    Yes, you need an ice cream spec unit.
    As far as engines go. They both put out maximum 68000 btu of cooling. Carrier uses 6 cylinder compressor tk uses 4 cyl. Carrier weighs 175 pounds less, and is a bit louder. Price is probably about the same.
    I have a trailer with ice cream spec and a carrier 7500 x4 unit. (Great dane). It serves me well, I would buy another. Look around frozen customers, most of them use carrier as well. If I didn't do frozen a lot and was more produce/meat/ less demanding for the unit, I would have went thermo king.
    Don't forget to plug the drain holes when doing frozen.
    Ryan423, BoostedTeg, DTP and 1 other person Thank this.
  5. DTP
    DTP Road Train Member
    1,281
    2,708
    Dec 9, 2014
    As the others have said, I wouldn’t buy just any conventional reefer for ice cream. I only hauled ice cream a few times but if I remember right I had to run the unit at -30. So it’ll definitely work the unit much more than hauling produce, milk, etc.
  6. STexan
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Bottom line is you want high capacity units with ability to cool down rapidly and deep, and want as much R value you can get in all 6 sides of the trailer. Trailers lose R value with age.
  7. Ridgeline
    22,439
    117,046
    Instead of asking in the new driver's forum, maybe calling a dealer who deals with this may be helpful.
    Just a thought.
    Hitman Thanks this.
  8. STexan
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    He probably did and was left almost dead of sticker shock, and hoped he could come here discover you can haul ice cream on the cheap, long term and without any issues and no doubt someone will come along and say just that.
  9. Hitman
    Hitman Mr. Gamer
    2,476
    15,509
    Sep 5, 2006
    Tioga, PA
    Or post his question here....Refrigerated Trucking Forum
  10. thelushlarry
    thelushlarry Road Train Member
    3,023
    8,999
    Jan 9, 2012
    glasgow ky
    I had a thought once but I forgot it!
  11. aussiejosh
    aussiejosh Road Train Member
    4,709
    5,409
    Aug 28, 2009
    Airlie Beach QLd
    Having hauled reefer for around 5 years have gotten to know that some trailers are only designed for refrigerated work unfortunately dispatchers don't bother checking this and send you off to pick up a load of frozen goods only to find its near impossible to get the thing down to the specified temp i spent about 5 hours one hot afternoon in the Oklahoma panhandle trying to get my reefer down to the allowable temp before i was allowed to leave finally had to unhook the trailer which worked wonders temp came down and off i went anyhow make sure the trailer you buy is designed for frozen freight they usually are better insulated and what ever else they do to help keep things super frozen.
