Buying a Used Truck and finding out actual mileage?
Discussion in 'Ask An Owner Operator' started by Michael 247, May 8, 2019.
  1. Michael 247
    Michael 247 Heavy Load Member
    894
    4,681
    Nov 20, 2017
    Dublin Va
    I'm looking at used Trucks..1990 to 2000..is there a way to find out if the mileage is actual ..A 1998 Mack with a 2 bunk sleeper..630,000 miles..Thats low miles...So I'm wondering if the mileage is right or if it's been setting a long time ?
  3. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    Could be if was running local short trips. Check the chassis very carefully for corrosion, spring hangers, axles,crossmembers ,flimsy/bent twisted frame rails on top of motor and other components on 20 years old truck. I had problems frame rails with one of trucks ,costly repairs damaging for other components.
    PE_T and OldeSkool Thank this.
  4. mp4694330
    mp4694330 Road Train Member
    1,529
    1,459
    Aug 30, 2010
    Chicagoland
  5. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    If it has an ECM you can scroll through the menu and check that
    Rideandrepair Thanks this.
  6. Michael 247
    894
    4,681
    Nov 20, 2017
    Dublin Va
    Good idea..i need to have it Dyno Tested and check Blowby too..
    blairandgretchen Thanks this.
  7. Shawn19
    Shawn19 Light Load Member
    117
    34
    Apr 20, 2019
    Hard to say from my experience I wont go by miles as so much as what work the truck was doing otr or local heavy hauling maintain history etc.
    PE_T Thanks this.
  8. Gdog66223
    Gdog66223 Road Train Member
    1,871
    2,569
    Dec 30, 2017
    Coal Town
    I had mine looked at the local KW dealer... Found out all the info I needed...
    You can also type the VIN in google and see which company owned it before you by looking at their inspection reports on safer...Give them a call and ask why they sold it and find out actual mileage...
  9. blairandgretchen
    13,380
    71,960
    Dec 9, 2011
    South west Missouri
  10. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    that is high mileage for having to sit in a mack. lol
    I have a feeling that that year mack is one of those with a computer controlled regular (sorta of) injector pump. I had an owner buy one and tried to run over the road, nobody but mack would touch the thing and when they told him the pump had to be sent back to mack to turn the fuel down, it was the final straw, and traded for an international before the day was out. lol
    It may be better back east, but out west mack were few and far between, as in measured closed to thousand miles between them, and would give you a range of weeks to get it in, even for a minor fix.
