Looking at a 2010 386 Pete with a c13 500hp single turbo 500k miles . What’s your experience with them ?
C13 Single Turbo 500hp worth buying ?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Brandon0928, Aug 29, 2022.
@D.Tibbitt Isn’t this about what you have?
Another Canadian driver and D.Tibbitt Thank this. -
Another Canadian driver Thanks this.
If it's a LEE, I'd stay away just because of legal issues of the parts falling off.
Another Canadian driver Thanks this. -
I'll make some assumptions here, correct as needed. A 2010 386 with a factory installed C13 would have an engine SN prefix of LEE. If it no longer has the compound factory turbos and it is 500 HP, it has been emissions deleted. No way some one converted single to made it work emissions compliant. Ask yourself, does running a truck that has had emissions modified a good fit for you. Keep in mind most dealers won't touch it for repairs and independent shops are starting to shy away too with increased crackdowns from EPA.
bjytech and Another Canadian driver Thank this. -
MACK E-6 and Another Canadian driver Thank this.
500 is pushing a C13 pretty hard, weren't those maxed out at like 450? If it's not a glider kit truck then you're gonna have some issues getting it worked on, unless you can do it all yourself
Oxbow, D.Tibbitt and Another Canadian driver Thank this. -
I wasn’t sure if you got a new one or not....D.Tibbitt Thanks this. -
MACK E-6 Thanks this.
