C15 Synthetic or Not?
Discussion in 'Ask An Owner Operator' started by Swift09, Mar 27, 2020.
  1. Swift09
    Swift09 Light Load Member
    77
    106
    Jul 4, 2019
    I bought my truck with a rebuilt mbn, has about 130k on the rebuild.
    I added a gallon of synthetic this week and it's leaking at the front casing.
    I want to do an oil change. Should I stick to regular? Or try synthetic?
    Recommendations on brands? Thank you for the help
  3. Judge
    89,063
    I would stick with rotella 15W-40.
    I always heard if there’s a place to leak synthetic will find it.
  4. Cat sdp
    Cat sdp . .
    21,086
    74,129
    Apr 8, 2012
    Orion's Belt
    I’ve used T6 forever in a C15...... fix the front cover.
    It was probably leaking before anyways.
    Orange713 and mtoo Thank this.
  5. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,732
    Jan 30, 2010
    keep stroking.
    First where's it leaking on the front cover ? Crank seal probably wasn't part of over haul if inframe. Probably ready to leak from age. Leaking from behind fan hub mount the one stud (top driverside) common issue of leaking. Two ways to fix. Cheap way,pull stud clean stud and hole use silicon adhesive (not to much) put on stud threads and install. Let it cure and it will stop leak. Or expensive way remove front cover and replace front cover and plate gaskets.
  6. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    Always use synthetic if you own it.
  7. Superhauler
    12,209
    100,732
    Jan 30, 2010
    keep stroking.
    I switched to synthetic blend oil (shaffers) and no leaks.
  8. PE_T
    PE_T Road Train Member
    Try to locate your “engine manual” online, which is not the same as your truck manual. There should be a section about engine oil types for your engine. I’d stick with what they recommend.
    I personally use synthetic blend for my DD15 engine (2013 model). Full synthetic is very expensive.
  9. moonshine powered
    moonshine powered Bobtail Member
    9
    14
    Oct 28, 2014
    Exactly this!
    I used to run T6 in everything I owned, when I purchased my truck eith a 2WS Cat there wasn't a drop of oil anywhere. Even on the 2000 mile drive home nothing. Swapped it over to T6, it was like I drilled holes all over the thing. I couldn't keep the oil in it. Went to Mobil delvac 1300... No leaks.
