Cabin not heating help.
Discussion in 'Volvo Forum' started by poe333, Nov 22, 2016.
  1. poe333
    poe333 Bobtail Member
    the blower motor and fan are working but no warm or hot air is entering the cabin.
    2001 Volvo Detroit diesel.
  3. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,381
    Jul 16, 2012
    Bentonville Arkansas
    Is coolant lines shut off to heater core ?
  4. Mattflat362
    Mattflat362 Road Train Member
    2,705
    5,768
    Feb 18, 2015
    Avon Lake, Ohio
    Do you smell coolant at all? I always suspect heater cores because I have replaced so many of them over the years! (cars and trucks and my Pete)
  5. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,996
    19,137
    Mar 9, 2014
    In a van down by the River.
    Just set it on fire then you will be warm.
    Getsinyourblood Thanks this.
  6. blairandgretchen
    13,632
    74,079
    Dec 9, 2011
    South west Missouri
    As said - trace heater hoses from firewall, looking for taps that are turned off. May be close to the engine.
    Do not turn off the one to transmission, if fitted.
  7. Pinner
    Pinner Medium Load Member
    410
    201
    Feb 14, 2010
    B.C.
    Does it have an air filter in the system like a Pete
  8. blairandgretchen
    13,632
    74,079
    Dec 9, 2011
    South west Missouri
    True - maybe a seriously clogged air filter?
    I think if the bunk is working, then it's probably taps turned off for summer.
    Hope he gets warm soon!
  9. snowwy
    snowwy Road Train Member
    20,590
    13,308
    Jul 6, 2009
    That old of a truck. Might have a water valve in the coolant hose also. The water valve has a cable that connects to the temp control slider knob. It's used to control the temp of the heater. It's possible the water valve is in closed position.
    That's if it has one. Or the temp blend door is in cold position.
    Check your heater hoses. If both hoses going to the firewall are hot. That's a plugged core. One should be colder then the other.
    That's on top of what others have suggested in checking that your water valves are open.
  10. DUNE-T
    DUNE-T Road Train Member
    7,014
    17,069
    May 10, 2015
    Detroit, MI
    Huh, I have the same problem
