Cabover O/O fuel economy question(s)
Discussion in 'Ask An Owner Operator' started by 85COE, Apr 3, 2022.
  1. 85COE
    85COE Light Load Member
    242
    505
    Aug 6, 2019
    Columbus, Ohio
    Okay, so it's looking like the worst time to put my truck on the road, but there is a high probability of it happening.
    My truck is the 85 Volvo White, with a 300 Cummins, rears are 355, with 24.5 tires
    i have not pulled a load with it, but would be restricting myself to flat land, minimal hills/mountains (no west coast, no south), mainly the midwest (OH, IN, IL, MI, maybe IA, MO, & KS).
    Any idea on the fuel economy I may be looking at? Originally, I was thinking 5mpg, but I've been told that it'll be closer to 3.5-4
    With the cost of fuel being what it is, would I be better off staying and driving someone else's truck?
  3. Judge
    87,747
    Probably be close to 4 mpg.
    Unfortunately I’ve driven coast to coast with a 300 cummins and a nine speed.
    It’ll do it. You won’t be the first one to the top of the hill, kinda a long slow walk.
    It’s up to you, that picture shows short wheelbase, I’d figure spring ride, a good air ride trailer will help
    12 ga, stuckinthemud and Bean Jr. Thank this.
  4. 85COE
    242
    505
    Aug 6, 2019
    Columbus, Ohio
    It is air-ride ... So i'll be spending about $3k just in fuel alone ... This sucks
  5. Judge
    87,747
    Pretty close at 4 mpg, if you’re figuring 3k miles a week
  6. kranky1
    kranky1 Road Train Member
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    I’d start by checking the CPL on that engine. If it allows uprate to 350 or 400 that would be my first move. Excepting trains or multi-axle trailers, Formula 400’s used to do 5.7 to 6 pretty easy at Canadian weights if you were half civil with the right hand most pedal.
  7. 85COE
    242
    505
    Aug 6, 2019
    Columbus, Ohio
    the CPL is 0633
  8. 85COE
    242
    505
    Aug 6, 2019
    Columbus, Ohio
    better pic of the plate
  9. BigCam9670
    BigCam9670 Medium Load Member
    417
    4,585
    Jun 12, 2012
    Hudson, NY
    Not sure on the cummins, but I have a 400hp 3406B and 15 speed in my k100, it does between 5 and 6 mpg depending which trailer I have, weight and wind. I did a round MA to FL back to MA with my conestoga couple weeks back, it was right at 5.7mpg. I'd think you'd be winding that cummins out a lot of the time, which will certainly not help your mileage.
  10. Lazer
    Lazer Road Train Member
    1,790
    2,850
    Jan 22, 2017
    Go over it with a fine tooth comb. Check alignment, all 3 axles, air filter, change out the differential oil to full synthetic 75w90, ditto on the hub grease, change tranny oil to synthetic 50w drive line oil, get everything as close to spec. as possible, then drive as if there is an egg on the accelerator. You may be able to squeeze 3/4 to 1 mpg extra. As you pull up to the fuel island, thank your luck stars your sled is paid for(hopefully).
    Keepforgettingmypassword and W923 Thank this.
  11. 85COE
    242
    505
    Aug 6, 2019
    Columbus, Ohio
    It is paid for.
    I'll be switching from van to flat, depending on the demand. Sticking to flat land as much as possible, unless a high paying load pops up for NYC
    PSM379 Thanks this.
