Can I remove the passenger seat from a company truck?
Discussion in 'Questions From New Drivers' started by Chi Town Steers, Mar 1, 2025.
  1. Chi Town Steers
    Chi Town Steers Road Train Member
    1,405
    2,960
    Aug 10, 2015
    From my company truck. I’ll just throw it on the top bunk and strap it down then put it back whenever they want their truck back. I want to remove it for three reasons.
    It shakes a lot for some reason. Vibrates and makes noise.
    I want to put a portable air conditioner where it is. (I haven’t worked out how I will do this yet or if it will work, I’m hopeful.)
    I don’t use it or need it.
    I don’t want to damage the truck or cause any problems, but I think it would be nice to have that extra space.
    Is this a bad idea?
    austinmike and D.Tibbitt Thank this.
  3. bad-luck
    bad-luck Road Train Member
    3,292
    6,056
    Nov 16, 2013
    Baltimore, Maryland
    I would read your employee hand book. It's possible that a mechanic could report it when you bring your truck for maintenance.
  4. rollin coal
    rollin coal Road Train Member
    13,269
    26,726
    Mar 29, 2008
    TN
    Not a good idea to have something like that riding in the bunk. You jam on the brakes hard enough it might end up busting your skull. Talk to your shop about it maybe they can fix it or remove it. Try airing it up if it's sitting on the floor and see if that helps.
  5. Ridgeline
    22,367
    116,012
    Just cut a hole in the back of the sleeper, put an A/C in the hole.
  6. tscottme
    tscottme Road Train Member
    Company may not allow it or they may only allow it if their shop removes it.
    Portable A/C consumes a lot of electricity. Think of running a 1000 watt microwave for HOURS. Portable (wheel around units) are twice as expensive, half as effective as a window unit AC.
    If you don't have a big APU & power inverter you are not running any portable or window A/C.
  7. D.Tibbitt
    147,441
    If u a company driver just ask the shop to do it.. I'm sure u wouldn't be the first driver to request that... I would not put it on the top bunk. Those seats are alot heavier than they look and awkward to lift.. I had quite a difficult time just getting mine out of my 386 pete. A couple years ago. It's tough to carry around...I'm not sure I'd be able to lift it over my head. I'd guess they are probably 50-60 pounds
    Taking out is easy. 4 floor bolts and a seatbelt bolt and a 1/4 inch quick connect airline
  8. austinmike
    98,379
    Company’s don’t want drivers tinkering with anything on the truck. My first gig they wouldn’t let’ us replace the wipers. Take it to a shop they said. So we did.
    Ask the company and see what they say.
  9. Chinatown
    Chinatown Road Train Member
    74,669
    169,721
    Aug 28, 2011
    Henderson, NV & Orient
    Some companies allow the driver to remove the passenger seat, so ask the shop about that.
  10. wulfman75
    wulfman75 Road Train Member
    2,102
    2,568
    Jul 15, 2010
    Athens, GA
    ask your company. some will let you, some won't.
  11. lual
    lual Road Train Member
    4,694
    8,412
    Oct 22, 2020
    SW Georgia
    Is your truck "car hop" ready?
    If not -- why not fix that, too....so you can be properly waited on at those drive-in restaurants during your DOT rest breaks....
    -- L
