Can Oil Bypass Filtration system Cut my Oil Maintinance Cost?
Discussion in 'Ask An Owner Operator' started by TruckerE, Feb 17, 2013.
  1. TruckerE
    TruckerE Bobtail Member
    I was looking in to getting a oil bypass filtration to save on the time of changing the oil. The system claims to remove all partical from the oil and all the moister. They said that changing oil every 10,000 miles can be decreased to every 50,000 to 60,000 miles. If this is true, than I need this. If you have any information about this please message me. I looked at a few different site but the one that gave me the most information was *spamspamspam* Look at it for me and give me your input before i make my purchase.
  3. Rooster_1
    Rooster_1 Bobtail Member
    28
    8
    Aug 8, 2012
    Dallas,TX
    Kleen oil is the filter system im looking at....called them directly and if I remember correctly they quoted me 725...now dont hold me to that but i think that was right. Also check out Filtration Systems and the Spinner II.
  4. TruckerE
    Which one is the best from your knowledg?
  5. Gentlemanfarmer
    Gentlemanfarmer Medium Load Member
    365
    384
    Feb 26, 2010
    Greenville, FL
    I would suggest Gold Cooast Filters and their byoass system. But you may want to try using a fluid analysis first. You can pick ip the kits from TA or Petro. Also depending on the make, model and year of your truck mist manufacturers today recommend an oil change interval of 40000 to 50000 miles.
  6. TruckerE
    This company allows you to refer individuals and they will pay you $100.00 per referral. Then you can use this money to off set your oil maintinance cost. What do you think.
  7. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    All of the different bypass units work pretty well. Once you get into the 1 and 2 micron arguments, you are really dealing with something that makes a difference in a controlled lab setting, but in the real world is not so critical. OPS, GC, FS2500, Amsoil, Spinner II, etc all do a very fine job. Some are easier to install that others, so that is a factor to consider. I know the FS2500 one comes with every hose, fitting, etc setup for a clean install on whatever truck/engine combination you have. No need to turn it into a Popular Mechanics project like some of the other units. Can do that one yourself and have the job done in an hour.
    Not only how much does it cost to buy and install, but how much does it take in additional maintenance costs and filter cost? Bypass filters vary in price and the recommended change intervals can be quite different. Also, how much makeup oil is needed when you do a filter change? Now I know for a fact that Gulf Coast takes the prize on needing the most make up oil for a filter change. In some respects, not a bad thing, but it adds to cost. The OPS, FS2500, etc use far less makeup oil, and are not near as messy to change out. The Spinner II requires no makeup oil and is very easy to change the one piece rotor container that the new ones are using.
    A bypass or centrifuge unit is always a good idea. Keeping the oil as clean as possible always is beneficial to an engine, whether you go for long drains or not. I don't try to set records for how long I go on an oil drain, but I have always used additional filtering on my engines. Whether you stick with OEM recommended drain, extend it 50%. Double it. Triple it. Or whatever, your engine will benefit from some form of additional filtering.
  8. mavljc
    mavljc Bobtail Member
    44
    24
    Jan 9, 2013
    The power cell looks like it is a toilet paper system, they work but you can build one yourself. Toilet paper systems have been around a long time. I would be afraid it would come apart and clog my system.
  9. pawpaw1
    pawpaw1 Medium Load Member
    396
    145
    Sep 9, 2011
    Dallas,Ga.
    I looked. Amway , anyone ?
    My experience , so far , is this. Switched to Amsoil , about a year and a half ago. They have a good By-Pass oil filter . Inexpensive , compared to some, in fact. Good oil anylasis , too. I switched , in Dec. , to the Oil Spinner II . I like it better. I think it costs over $600.00 , but I think it's worth it.
    This call is all yours. Gulf Coast is Quite expensive , but I've heard nothing but good things about them.
    I think it's more a matter of personal choice , what you think will work best for you.
    Good Luck !
  10. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    I really recommend using a spinner filtration system. they are great IF plumbed and installed properly.
    I spent 40 years doing engines and you can believe all the propaganda you want, I saw the difference, changing the oil at a longer interval, the motors wear out, and fail early. Be it a Cat Cummins or Detroit. The dirtier the oil the more the wear, rings especially.
    When you change the oil it will use nothing, after a while it will start using oil, that should be the maximum 1/2 life, and that is for old engines.
    An oil change is the cheapest overhaul you will not need. Using some fancy expensive oil, for a longer period, is 100% BS. I was involved with a test of synthetic oil, Cost wise, engine wear, mileage gain, and internal cleanliness, in every aspect it was a failure, and it was done over 600,000 miles on 6 trucks.
