can someone explain HOS reset to me?
Discussion in 'Questions From New Drivers' started by morpheus, Sep 27, 2015.
  1. morpheus
    morpheus Medium Load Member
    392
    242
    Jun 12, 2014
    Hello,
    Can someone explain HOS and the reset to me?
    My understanding is that once you hit that 70hr mark you must stop for 34 hours. Since you are out a few weeks at a time I would think that it would not be considered home time, of course.
    A little clarity would be helpful.
    When you are "stopped", you cannot move the truck at all? Or can you move it to an area that you want to be?
    Thanks
  3. Joker_wss
    Joker_wss Bobtail Member
    12
    Sep 27, 2015
    You don't HAVE to do a 34 hour restart. You will gain back the hours you drove 8 days ago. This is called running recap. However a 34 hour restart would reset you back to 0, but you could in theory run 12 months straight without a restart, you would just be limited to the hours you gain back each day.
    Are you on Elog? There would be somewhere it will say something like "Hours to be gained" and that'll be what you will have the following day.
  4. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    A reset is not mandatory.
    You have 70 hours in eight days available for on-duty/driving time. If you get to the 70 hours in eights days you cannot drive again until you either take a reset or recapture hours at midnight of the eighth day (as it turns over to the ninth day) that were worked on the first day. Example; you had 1.25 hours on-duty and 8.75 hours driving on the first day, those 10 hours are added back to your available hours for your 70/8 on day nine.
    There is an FMCSA Guidance (Question 26) for Personal Use of the CMV for the purpose of short trips to restaurants, local lodgings, terminal to home, etc., when you are unladen and off-duty. However, some companies do not allow drivers to make use of this Guidance. Personal Use is not to be used to "move forward" to your next load.
  5. Straight Stacks
    Straight Stacks Paper Cha$er
    2,930
    20,768
    Jul 18, 2015
    Alabama Gulf Coast
  6. Hudson_MacBeth
    Hudson_MacBeth Medium Load Member
    350
    397
    Sep 3, 2015
    In a nutshell:
    14 hour rule: When you start your day (coming off of at least a 10 hour break,) you start the clock for a 14 hour day. So, if you start your "day" at 6:00AM, you must not drive after 8:00PM. You can still do "On duty, not driving," but you must not drive*
    11 hour rule: You may drive up to 11 hours in a given work period, as long as it is done before your 14 hour clock runs out. At or before the 8 hour driving mark, you must take a minimum 30 minute break.
    70 hour rule: This rule takes into account the last 8 days. You add up your "Driving" and "On Duty, Not Driving" lines for the past 8 days, and if they are at 70 hours or more, you may not drive. This time period is a "rolling" 8 days, meaning that when your log time passes midnight, you could gain hours back by reworking the past 8 days.
    34 hour reset: If you take 34 consecutive hours off, your 70 hour rule resets to zero, regardless of the last 8 days.
    * A split break can be made, provided that 8 hours is taken in the "Sleeper Berth" this will extend the 14 hour window by the amount of time in the sleeper berth. After either the remainder of your 11 hours driving, or finishing out the new 14 hour window, you must take at least 2 hours off duty or sleeper berth.
    I can explain recap hours a little better if need be.
    Mattflat362 Thanks this.
  7. supersnackbar
    18,666
    45,027
    Aug 19, 2007
    Your Town, USA
    But don't forget that if you ever exceed your 70, then a 34 cannot be taken.
    Some companies prefer that you show time for your posttrip rather than on your pretrip so that you can use every last minute up to your 70 as drive time, then the 15 minutes many companies require for a posttrip can be done after you hit 70 legally...it just screws up a 34, and takes 15 minutes off of your total for tomorrow.
    And I know I will get grief about this, but if you have an android phone, there is an app just for recapping logbooks.
  8. xsetra
    xsetra Road Train Member
    5,096
    6,945
    Aug 21, 2011
    You can take a 34 anytime. Not only at the end of your 70
  9. jbee
    jbee Medium Load Member
    664
    619
    Jun 3, 2011
    NC
    Also, to throw a wrench into this thread, we all need to keep our fingers crossed that the suspension of the former rules stay in place and don't get rolled backed to the 1 only every 168 hrs, to include 2 periods covering the 1am to 5am timeline pending the passage of the funding bill, at the end of this month.
    The FMCSA still has yet, to produce any data or documentation to show any differences, (which is due by Sep 30) since the suspension went into effect back in Dec, 2014.
    An indication, based on the WH releasing a statement stating our commander "who knows everything" in chief, may follow the advice of his advisors and veto DOT funding, unless the suspension is lifted and those nuttier than ever rules, go back into place. :rolleyes:
  10. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    You can DO anything you want or need to DO.
    Rules were meant to be broken.
    thelushlarry and Straight Stacks Thank this.
  11. CasanovaCruiser
    CasanovaCruiser Road Train Member
    1,712
    2,669
    Jun 2, 2015
    Indiana
    A 34 is when a driver gets to do his laundry drunk
