Can we use bubblegum to fix a gladhand seal leak?
Discussion in 'Questions From New Drivers' started by Flankenfurter, Feb 10, 2021.
  1. Flankenfurter
    Flankenfurter Light Load Member
    133
    112
    Jan 8, 2021
    USA
    One of the CDL practice test questions I read mentions using bubblegum as a quick fix for a leaky seal in a gladhand. Could this be true? That's a lot of Bubblicious! :p What are some other tips for fixing a leaky air hose on the road?
    If one of the glad hands on your blue air line is missing a seal, . . .
    a. common bubble gum will work until you can find a new seal.
    b. you could end up with a service line air leak. (answer)
    c. you could end up with an emergency line air leak.
    d. you would not know until you set your parking brake.
  3. WesternPlains
    6,333
    56,040
    Sep 1, 2017
    Rapid City, SD
    I expect this to be bait for you to answer incorrectly.
    You actually should have a few gladhand seals in your truck.
    I worked for an idiot. One day he hooked up blue line. It was leaking. He licked the seal. Then no leak. He said: see... good as new.
  4. Chinatown
    Chinatown Road Train Member
    76,643
    178,291
    Aug 28, 2011
    Henderson, NV & Orient
    I've seen that also. Some drivers wipe a little grease from the 5th wheel on it, and the leak stops. Those seals get a little hard & dry with time and just need a little moisture.
    Carry a few with you in the truck because sometimes drivers will steal those from other trailers.
  5. Flankenfurter
    133
    112
    Jan 8, 2021
    USA
    LOL!
    There might be people taking the test thinking, hmm...bubblegum. Never thought of that.
  6. Flankenfurter
    133
    112
    Jan 8, 2021
    USA
    Good one, Chinatown. Noted.
  7. De Trucker
    De Trucker Medium Load Member
    568
    843
    Apr 21, 2015
  8. Bill51
    Bill51 Road Train Member
    1,184
    2,982
    Jul 27, 2015
  9. Dockbumper
    Dockbumper Road Train Member
    3,778
    9,861
    Apr 29, 2020
    SoulScream84 Thanks this.
  10. SoulScream84
    3,426
    26,260
    Mar 21, 2020
    Hell when I worked for CFI I had glad hand seals, and 2 of every light I'd had on a trailer to that point that I carried in a milk carton. I remember 1 drop yard encouraging us to remove the lights when we dropped so we'd have lights for the trailer we got back.
  11. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    Glad hand seal are the cheapest, easiest to change and arguably most often changed part(especially d/h operational) on a truck.
    Could someone explain why they don't have extra?
