Can you make your own fuel? Biodiesel?
Discussion in 'Expediter and Hot Shot Trucking Forum' started by hertfordnc, Nov 15, 2013.
  1. hertfordnc
    hertfordnc Bobtail Member
    20
    Oct 30, 2013
    Are there legal obstacles to running on untaxed home-made fuel? The biodiesel guys are making good fuel for around $.80/gal - If you could carry 100 or 200 gallons it would change the cost per mile considerably.
    I googled around and didn't find anything so i assume it's a non-starter but I'm curious
    I know, most professional truckers would be afraid to put backyard fuel in a $70,000 truck but people are doing it.
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    you must carry many fuel filters in truck, cold is hard on bio. type fuel.
  4. brian991219
    brian991219 Road Train Member
    2,924
    5,816
    Aug 10, 2013
    Lords Valley, PA
    You can do it but you would still have to pay the taxes on it since you are required to report the miles run and fuel purchased to the states. The penalties for running non-taxed fuel are substantial if you get caught. It may be cheaper to make your own but in the long run it may not make much of a difference unless you are in an operation where you come home almost daily to refuel. Trying to get enough feed sources to make 800 to 1,000 gallons a week would prove difficult. Good question but not likely to be a viable option right now.
    blairandgretchen Thanks this.
  5. blairandgretchen
    13,240
    70,603
    Dec 9, 2011
    South west Missouri
    David Blume, I think is his name. I bought his book on making your own ethanol from scratch.
    Absolutely possible - but as Brian says, viability is the question.
  6. 900,000-tons-of-steel
    900,000-tons-of-steel Road Train Member
    1,511
    896
    Aug 17, 2012
    Florida
    There's a former USF student in Tampa converting diesel engine autos to run on used vegetable oil for 1-2K per vehicle. He's been in the news numerous times and there are a decent number of those vehicles running around the bay area. Wonder how it would work with a big truck.
  7. rjw
    rjw Bobtail Member
    7
    Nov 14, 2013
    When you figure your time and trouble, I'm not sure it would be viable. You would have to have a vegetable oil source, pick it up and clean it. Also should use some additives for your engine. could use a lot of your spare time!
    paul 1052 Thanks this.
  8. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    I tried it on a Ford pickup and my friends who talked me into it have it on 2 vehicles and love it but
    1 It's messy, nasty and dirty
    2 You can't get enough because in VA aused oil and dead animal retreival company got a law passed that you could only havee 180 gallons on hand
    3 Filtering is one problem , heating it in cold weather another, wax another and takes a lot of room to do the filtering including cintrifugal filters.
    4 It smells like french fries and makes you stop at Golden Arches Supper Club every 50 miles to eat
  9. jldilley
    jldilley Medium Load Member
    485
    406
    Oct 13, 2013
    Indianapolis, In
    Nice. Grab a big mac then go around the back to the nasty grease HOLDER AND FUEL UP
  10. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    I use WMO in my F350. You just have to dewater and clean it.
    A good portable centrifuge is from Pabiodiesel, but you still have to dewater. Never trust your fuel source. You can use 100% WVO, but you need to modify the fuel system. You can drive and clean your fuel at the same time. Many oil change facilities in small town would love to give you free fuel :)
    I've put more than 15k miles on my truck using WMO without any problems. I just got 1300 gallons of WVO that I am looking forward to using if I ever run out of WMO. I have about 800 gallons left of WMO ;)
  11. Ridgeline
    22,128
    113,386
    Using it straight in any modern diesel is rather dumb. it should be processed to get rid of the glycerol in the oil (fat) and clean it up.
    The process isn't clean or nice, it involved lye and heat. leaves you with clean fuel and soap making products.
