@reeferwrencher I want to see if you’ve come across this problem. After a defrost cycle the expansion valve goes to 20% then to 0% and then back to 20% and unit shuts off. It’ll do this about once a month and 2-3 times back to back. Is that a sign that the expansion valve is going bad or is there another cause?
Carrier 7500 code 28
Discussion in 'Refrigerated Trucking Forum' started by 062, Aug 16, 2020.
I ve never seen that,but to my knowledge the electronic valve is very reliable. Is it cooling good otherwise? And is defrost working ok?
062 Thanks this. -
Yes. I don’t know for sure that’s the cause, I just noticed it yesterday and it seems odd. I’m not able to see all the functions on the screen at one time. When it shut off I scrolled up and the suction pressure was 61.
Make sure the ball is up and check plug connection on sv2.If any problem with that solenoid it will run into a vacuum right away and stop cooling
