Carrier reefer question
Discussion in 'Refrigerated Trucking Forum' started by Catrachotrucker, Apr 22, 2020.
  1. Catrachotrucker
    Catrachotrucker Light Load Member
    71
    26
    Apr 15, 2019
    Does anyone know what it means when the cool symbol switches to heat for a couple seconds on a reefer? The temperature is fine at the set point of 23
  3. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Your refer is cycling that's normal ,if it goes to heat for a while it's defrosting, no worries good day mate
    Trucker61016 Thanks this.
  4. supertrucker79
    supertrucker79 Light Load Member
    135
    251
    Feb 4, 2019
    Pittsburgh, PA
    Moisture condensates inside and freezes up preventing air flow, thus the ability to keep the load cool. So, to prevent that from happening the coils get heated up from time to time to melt the water. Ever run a window ac unit on a super humid day and it stops blowing cool air? Same thing going on there, except with a window unit, you have to turn it off a while or run in fan mode till the ice melts.
