Carrying chilled meat and less chilled salad in single-temp zone
Discussion in 'Refrigerated Trucking Forum' started by mjcgoforit, Nov 19, 2021.
  1. mjcgoforit
    mjcgoforit Bobtail Member
    Hello everyone!
    Just wondering if I could get some advice here.
    I run an organic food business, delivering fruit and veg, particularly leafy veg. That should be stored between 50-57 degrees for optimum preservation.
    Some customers are asking me to deliver meat. However that should be stored between 35-39 degrees.
    Trouble is my van (10m3 cargo) is single-temperature zone refrigerated. There won't be much meat, but looking to make it a regular thing if possible. The meat will already be packaged, shrink-wrapped or on heat-sealed trays (won't be loose).
    I am wondering if anyone could suggest me some possible solutions to this dilemma? I was thinking an ice-box with ice that would lower the temperature even further whose temp would be monitored.
    Thank you in advance
  3. bad-luck
    bad-luck Road Train Member
    3,283
    6,045
    Nov 16, 2013
    Baltimore, Maryland
    Most drivers use a bulkhead when hauling multiple temp loads in reefer without a multi temp unit. You will have to experiment to make sure that you can maintain these temps. I paid $1176 for my bulkhead around 7 years ago. I don't know what they cost now.
    mjcgoforit Thanks this.
  4. REO6205
    REO6205 Road Train Member
    13,172
    60,493
    Feb 15, 2014
    California.
    Will the vendor for the meat make deliveries?
  5. buzzarddriver
    3,540
    10,181
    Feb 1, 2011
    Dallas, TX
    Leafy veg is hauled at 35d. Meat is hauled at 26d. If you are hauling local, you could haul both at 35d and not worry with a bulkhead.
  6. mjcgoforit
    Thank you, this is the kind of response I was looking for from a proffesional in the field. Investigating bulkheads now and in touch with some companies who can help me. Thanks everyone else for your replies too.
  7. bad-luck
    3,283
    6,045
    Nov 16, 2013
    Baltimore, Maryland
    Your welcome, and good luck.
