Cat c-15. 150 degree thermostat
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Cajuncowboy654, Jul 27, 2019.
  1. Cajuncowboy654
    Cajuncowboy654 Light Load Member
    138
    34
    Jun 4, 2019
    Recently bought a Pete with a c-15 ACERT . Previous owner told me they put 150 degree thermostats in. He gave me some 180 degree thermostats and said they never got around to changing them out.
    Are the 150s ok or should I swap them out?
    Truck never gets hotter than 150 degrees, is this keeping the engine too cool? Will it hurt anything?
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Not sure that it would hurt anything on the motor but won't get very warm in the cab during winter.
  4. Cajuncowboy654
    138
    34
    Jun 4, 2019
    I'm in south Louisiana so winters aren't very cold, just want to make sure running that cool wont cause engine issues as every other cat I've ever run stayed near 180- 200
  5. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Put the proper stats in. Your not doing the engine any favors running it at 150 all the time . Stock is 192 cat stats
    Oxbow, spsauerland, AModelCat and 2 others Thank this.
  6. Cajuncowboy654
    138
    34
    Jun 4, 2019
    I guess the real question I have is, will it hurt anything to leave them alone?
  7. blairandgretchen
    13,430
    72,405
    Dec 9, 2011
    South west Missouri
    What he said.^^^
    Oxbow Thanks this.
  8. WREN
    WREN Medium Load Member
    378
    239
    Jul 17, 2017
    Florida panhandle
    Yes, its not good for cats to have lower stats in them. They are designed/engineered to run at higher temps for better performance
    Oxbow and swaan Thank this.
  9. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Probley will . Condensation wont properly burn off in the engine.
    Combustion wont properly combust leading to soot buildup.
    Diesels love heat. They dont have spark plugs to ignite the mixture like a gasser!!
    Put the right stats in and quit trying to re engineer everything.
    Oxbow, spsauerland and AModelCat Thank this.
  10. Cajuncowboy654
    138
    34
    Jun 4, 2019
    Well I swapped them out because I had the coolant drained already but I didnt try to re engineer anything.
    The 150 thermostats were already in the truck when I bought i .
  11. rollin coal
    rollin coal Road Train Member
    13,340
    27,027
    Mar 29, 2008
    TN
    I was told to always let my C15 warm to a minimum of 160* before taking off especially if under a load. If you do drive it cooler than that take it easy and dont romp on it until its warmed. The liners could drop because everything hasn't warmed/expanded to operating temp. You did the right thing I wouldn't have driven it until it had the right regulators in it. I'd actually be concerned as to why they really sold it if they had been driving it around like that....
    Oxbow and blairandgretchen Thank this.
