Cat C15 oil pressure issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dave1837, May 26, 2020.
  1. Dave1837
    Dave1837 Road Train Member
    1,402
    4,348
    Nov 16, 2019
    Pennsylvania
    I drove a 2007 379 with a C15 ACERT, it had a 625 until it scattered around 898k. A brand new 550 was installed about 13k ago. Today when I left my house I noticed my oil pressure was around 40 psi after a 20 minute warm up, as opposed to the normal 60-65. As the oil warmed up it dropped to about 25. I pulled over and let it idle, then it dropped down to 10. Oil is full, oil temp is normal, no knocking or pinging is occurring. I drove it to my load point a few miles away and shut it down again, then turned the key on to self test the gauges. With the key on, engine off, the gauge will jump up to 75 psi, then when I start it, it will drop back down to 10. Faulty sensor?
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Thats what it seems to be, later it may set off the stop eng. light and shut off your eng.
    A5¢ and Dave1837 Thank this.
  4. 062
    062 Road Train Member
    6,291
    33,837
    Oct 20, 2013
    Need to put a manual gauge on it to confirm. ASAP
    TGUNKEL, A5¢, Doealex and 1 other person Thank this.
  5. Dave1837
    1,402
    4,348
    Nov 16, 2019
    Pennsylvania
    It did this once before but fixed itself after a few minutes. Taking it to a shop to have it checked out
  6. AModelCat
    161,681
    Sounds like a gauge issue IMO but I'd definitely put a test gauge on it to make sure.
  7. Dave1837
    1,402
    4,348
    Nov 16, 2019
    Pennsylvania
    It was a bad sensor. My A/C stopped working as well on my way to the shop so I pulled over and found the belt was gone, shredded all through the engine bay. What a day
  8. Dave1837
    1,402
    4,348
    Nov 16, 2019
    Pennsylvania
    Thank you, everybody for your input
    062 Thanks this.
  9. Chubby Fly
    Chubby Fly Medium Load Member
    569
    797
    Nov 25, 2019
    yeah on my 379, i can tap the gauge and get a few more psi out of lol. Stock gauge is mechanical too. But i guess they wear out just like anything else
    650cat425 Thanks this.
