CDL Practice Test
Discussion in 'Questions From New Drivers' started by CJMorey, May 10, 2011.
  1. CJMorey
    CJMorey Bobtail Member
    35
    6
    Apr 16, 2011
    Jackson,Michigan
    I would like to take a practice test for the Michigan CDL Test and Endorsments, does anyone know where I might be able to obtain this piece of information thanks.
  3. rookietrucker
    rookietrucker Trucker Forum STAFF Staff Member
    10,061
    7,055
    Jul 15, 2007
    TEXAS
    CJMorey Thanks this.
  4. CJMorey
    35
    6
    Apr 16, 2011
    Jackson,Michigan
    thanks for the advice on this site I have practiced a lot on this but these are knowledge questions, are these not different than the CDL test questions. and if so where can I find the CDL questions that they would ask?
  5. Rerun8963
    Rerun8963 Road Train Member
    3,917
    2,012
    Mar 30, 2006
    ova-hereee
    you WILL NOT be able to get the actual tests your state has..every state "rotates" so to speak the CDL test questions, this way no one can "memorize" them. this also cuts down any chance of cheating, if someone is sitting next to you. you would each get different tests..
    the only thing that can BE recommended, is that you get the CDL book, read it all the way through, go to the websites and take practice tests.
    PAY CLOSE ATTENTION to the way the questions are worded, like for instance, "which would you always do"..
    "what should you never do"
    "what is most likely to happen"
    "what will happen"
    and so on and so forth..you MUST READ the question in it's entirety. and NEVER remove a word or add a word to make it SOUND good to you....
    read the choice of answers and 9 times out of 10, the FIRST answer that pops into your head, IS THE RIGHT ANSWER....!! DO NOT second guess your answer...!!!
    www.roadwars.com
    www.layover.com
    Strider, CJMorey and Flying Dutchman Thank this.
  6. Flying Dutchman
    Flying Dutchman Road Train Member
    1,274
    522
    Nov 2, 2009
    Northern California
    The practice tests are pretty accurate and will get you used to the way questions are worded for the tests. Like rerun said, they are not all the same, but rather worded in various ways to keep you on your toes. In CA, they dont even let you take your failed/completed tests home to study. Online practice tests are your best bet.
  7. Pa geargrinder
    Pa geargrinder Light Load Member
    58
    12
    Aug 1, 2010
    Pa
    If you read thee manual as Stated in earlier Post.
    Then take the practice tests on cristcdl !
    If you have problems in any category go back to manual and read that section.
    Once you can achieve 90s and 100s on the cristcdl tests you will have No Problem Passing your actual test !
    Read the entire manual First then later read it through again so it all embeds! lol :biggrin_25514:
    Pa.
  8. Elendil
    Elendil Heavy Load Member
    921
    626
    Mar 27, 2011
    Ottawa, IL
    The cristcdl questions are almost word for word what was on the CDL (and endorsement) test in Illinois.
    CJMorey and Freebird135 Thank this.
  9. CJMorey
    35
    6
    Apr 16, 2011
    Jackson,Michigan
    thanks for all the great replies, if anyone has anymore please leave them here thanks.
