CDL Test question on brakes
Discussion in 'Questions From New Drivers' started by Truck4Fun, Oct 27, 2013.
  1. Truck4Fun
    Truck4Fun Bobtail Member
    27
    14
    Oct 6, 2013
    Pasadena, Calif
    Studying for the CDL exam. Came across the below question and answer from a study guide.
    Question: Which of these is NOT a proper time to apply the parking brakes?
    Answer: If the brakes are very hot (e.g. after just coming down a steep grade)
    Parking brakes aren't used when coming down a steep grade. Are they?
    Huge Thanks for response(s).
  3. mclass555
    mclass555 Light Load Member
    184
    88
    Jun 5, 2013
    that is the right answer. Brakes are brakes, you are over thinking it
  4. jbee
    jbee Medium Load Member
    664
    619
    Jun 3, 2011
    NC
    Why do they call them "Parking Brakes?" Think about it for a minute. Are you moving or parked?
  5. 25(2)+2
    18,756
    45,804
    Sep 18, 2006
    the road less travelled
    The brakes on a truck, are compound actuated, with the same actual shoes and drums, or pads and rotors with a disc brake setup supplying the braking force for either braking or parking, so if the brake parts are hot, applying the parking brakes sets those hot parts together.
    Technically, anytime brakes are actuated they are being used, so the answer to your question is yes, they were being used coming down the steep grade.
    Passin Thru and Truck4Fun Thank this.
  6. HotH2o
    HotH2o Road Train Member
    4,100
    4,868
    Sep 23, 2012
    Read the answer again. It doesn't say while coming down a steep grade it says after coming down a steep grade.
    heyns57 Thanks this.
  7. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    The others posters are correct, and hopefully you now have a better understanding.
    I'll put it another way, just in case you're still unsure.
    You ask.. "Parking brakes aren't used when coming down a steep grade. Are they?"
    No... BUT many of the same brake parts are used for both systems (parking & service), so technically, yes. But read on for an explanation...
    Most of the working/active brake parts, (such as the brake shoes, brake drums, S-cam, and slack adjusters) are the same exact parts in use, whether you are stopped and applying the parking brakes (red/yellow dash valves) OR moving with the service brakes applied (brake pedal). The main parts that get hot are the shoes and drums because of the friction between the shoe and drum, when applied while driving.
    So their point is... don't use the parking brake until the brakes cool a bit. If you stopped and applied the parking brake too soon, you are pressing overly hot brake shoes against an overly hot brake drum. Leaving parking brakes NOT applied will allow a small gap between these parts, for quicker brake cooling.
    Truck4Fun, DoneYourWay and Marlin46 Thank this.
  8. white wolf
    white wolf Light Load Member
    287
    131
    Jul 1, 2013
    minneeessoooota
    First off you should never apply the parking brakes while moving unless it is a dire situation and as far as the brakes going down a grade and being hot well that is more of a circumstance of improper breaking it is called brake fade as a result of riding the brakes and improper enginge retarding and being in the wrong gear
    DoneYourWay Thanks this.
  9. heyns57
    heyns57 Road Train Member
    2,209
    1,011
    Dec 30, 2006
    near Kalamazoo Speedway
    I think you are all missing the point. The brake drums expand when hot. Setting the spring brakes with hot drums may cause the drums to crack as they cool off and shrink. The springs may not compress with the cooling drums due to friction at the shoe anchor pins, etc.
  10. KW Cajun
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    That makes sense.
    To be honest, I had always thought it was to prevent "overcooking" the linings of your shoes by having a red hot brake drum (figuratively, tho they can get RED hot too) tight against/around them.
    But the OP's question was also about confusion over brake parts/systems (parking vs service).
    Truck4Fun Thanks this.
  11. milesandmilesofroad
    milesandmilesofroad Light Load Member
    148
    200
    Oct 9, 2013
    This is the area of the CDL test that causes people to fail. Study, study and study again.
    Truck4Fun and KW Cajun Thank this.
