Cdl written test for buses
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Karigarciaee, Feb 3, 2018.
  1. Karigarciaee
    Karigarciaee Bobtail Member
    11
    5
    Feb 3, 2018
    hey i had a question if anyone could answer me i took the cdl tests at the dmv i took 4 tests which were passenger endorsement, knowledge, commercial c, and airbrakes i passed all 3 but airbrakes no would that mean i would have to retake all the other tests again if i used up the 3 chances i had for airbrakes would that mean i would retake all or just go pay and take airbrakes? i took it for California
  3. kemosabi49
    10,663
    45,727
    Jan 13, 2013
    SW Arkansas
    For one thing air brakes is not an endorsement. If you don't pass the test, you will have an air brakes restriction put on your license. If you passed the rest you are ok there. Go back in, after a little studying, and pass the air brakes test. Good luck.
    Karigarciaee Thanks this.
  4. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    Air brakes are very important. If you don't have it you probably will not be able to use a heavy truck or bus in America because there are none that don't use airbraking systems. That is one restriction (Along with auto only, non manual) you do not want.
  5. Karigarciaee
    11
    5
    Feb 3, 2018
    So does that mean i can’t retake the test at all and the restriction would still be there?
  6. Karigarciaee
    11
    5
    Feb 3, 2018
    But does that mean i can still go back pay for the air brakes test and do it and pass would that mean the restriction would be removed?
  7. x1Heavy
    34,017
    42,135
    Mar 5, 2016
    You have to have airbrakes, which means you need to touch up and study the subject until you pass that particular test, at that point the restriction should be taken off. It is a important component to trucking, and sometimes life depends on your knowledge of the system among other things.
  8. Karigarciaee
    11
    5
    Feb 3, 2018
    Yes i am well aware that air brakes is very important i almost passed it but some questions are just very tricky I’m aware of the air brakes but like i said there are some tricky ones that get you i just gotta study extra harder to remember i missed like 5 every time and i can only miss 3
    x1Heavy Thanks this.
  9. kemosabi49
    10,663
    45,727
    Jan 13, 2013
    SW Arkansas
    yes. Just pass the test
  10. GypsyWanderlust
    GypsyWanderlust Medium Load Member
    386
    568
    Jan 1, 2018
    I’m not a bus driver but I guarantee you need that ability to use air brakes unless it is small. Also if you are planning on driving a full size coach/bus you need a Class B not C.
  11. GypsyWanderlust
    386
    568
    Jan 1, 2018
    Regarding the air brake test questions, watch a JJ Keller / or similar YouTube on pre-trip inspection on airbrakes. It is a lot easier to remember when you actually know what the components are and what you are looking for instead of just memorizing text.
