change rear end ratio or change transmission
Discussion in 'Trucks [ Eighteen Wheelers ]' started by spurmonkey, Nov 7, 2020.
  1. spurmonkey
    spurmonkey Bobtail Member
    8
    8
    Nov 7, 2020
    I have a 98 379 with a 550 emodel , 18spd, and 370 rears.
    hauling cattle and hay. my problem is im topped out at 72 mph and cant pull a hill in 18th this truck has all limits taken off , turned to 550hp, pulls great in everything but the high hole. my question is would i be better changing to 355 or 336 rears or change to a 13 over tranny and leave the 370s? i dont need to run 120mph, lol i would just like to run the speed limit in some states 75-85 and be able to hit a hill hard enough that im not running 50mph at the top.
    thanks
  3. ErieMcDreary
    ErieMcDreary Medium Load Member
    460
    393
    Dec 4, 2016
    Erie PA
    Choose one;
    Pull hills. Lower gears (higher numbers) will help, but limit speed.
    Higher speed. Higher gears, (lower numbers) will help but limit pulling power.
    What rpm are you turning at 72mph?
    I'm turning 1500 at 65 with a 10spd and 3:55's.
    Rideandrepair Thanks this.
  4. spurmonkey
    8
    8
    Nov 7, 2020
    at 72mph im pulling 1650rpm also 11r 22.5 tires
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,297
    Apr 9, 2009
    Humboldt, Sk
    No matter the gearing , how fast you can go up a hill is solely reliant on horsepower.
    Modern 18 or 13 speed have same ratios at least in top three gears. Your 1998 may have different ratios if your can find the model number of your transmission.
  6. AModelCat
    161,606
    Gearing is for speed and startability. Horsepower is what gets the work done.
  7. blairandgretchen
    13,659
    74,329
    Dec 9, 2011
    South west Missouri
    95 379 S60 - I went to 3:55 from 3:70 on 24.5 LP - 13 speed.
    Was 65 at 1500, now 70 at 1500.
    I like it better, because I can run 12th at 1500 for 60mph, or 13th for 69-73 comfortably.
    Lost a little’climbability’ - I wouldn’t go 3:36.
    Aren’t 11R 22.5 almost the same as LP 24.5?
  8. blairandgretchen
    13,659
    74,329
    Dec 9, 2011
    South west Missouri
    My thoughts too. Get the numbers and check, but at least the top 2 , direct and over, are probably the same.
    You’ll get a lot of life out of the engine easing it up the grades, and rolling on the flats, shifting and watching boost and pyro, than you will mashing hammer.
    Rideandrepair and Swine hauler Thank this.
  9. ErieMcDreary
    460
    393
    Dec 4, 2016
    Erie PA
    If you're "topped out" at 72 and only 1650rpm, all your limits are not taken off. That motor should turn up over 1850.
    Rideandrepair and AModelCat Thank this.
  10. 062
    062 Road Train Member
    6,288
    33,827
    Oct 20, 2013
    Sounds like a stock 550 lo-nox file. You need to find a pre lo-nox file or have a custom tune installed. What Hp rating was the motor from the factory?
  11. BoxCarKidd
    BoxCarKidd Road Train Member
    4,525
    6,586
    Aug 26, 2014
    Close enough you can run them side by side and 5 MPH slower than an 11 R 24.5.
