Changing a flat?
Discussion in 'Questions From New Drivers' started by Hayabusa55, Aug 20, 2013.
  1. Hayabusa55
    Hayabusa55 Bobtail Member
    26
    18
    Dec 17, 2012
    So I am a local delivery driver and just came out of a stop and noticed my passenger outside drive tire was flat. Called my warehouse and they're sending someone to change it. They're also gonna change the other side drive because the tread is thin. (Bout time they get around to it, I had to request that one).
    my question is, do I need to drop my trailer or can they do it still hooked? If they need me to drop, I can already have that done by the time they get here. Thanks!
    DoneYourWay Thanks this.
  3. sfd714
    sfd714 Bobtail Member
    39
    10
    Jul 2, 2013
    I find it easier with the trailer unhooked, but it can be done hooked up.
  4. deskdriver
    deskdriver Light Load Member
    241
    141
    Aug 6, 2013
    it can be done either way.
  5. scottied67
    scottied67 Road Train Member
    10,826
    12,673
    Mar 14, 2010
    california norte
    If you have some 2x6's or even 2x4's handy, sent them on the inside duals and drive up on them to get the outside tire up off the ground before the tire guy gets there.
  6. RAGE 18
    RAGE 18 Road Train Member
    1,529
    941
    Jan 31, 2011
    GOLD£N☆STAT£
    Don't matter the air jack will lift the truck off the ground with ease.
  7. Lostkeys
    Lostkeys Heavy Load Member
    903
    6,243
    Jan 8, 2011
    Archbold,OH
    Only if you have the stud pilot wheels.
  8. deskdriver
    241
    141
    Aug 6, 2013
    those are pretty rare now adays
  9. WorldofTransportation
    WorldofTransportation Heavy Load Member
    702
    577
    Sep 20, 2009
    Your mother
    That isn't true.... If it is an outside tire you don't even have to take the wheel off the truck if you know what you are doing.. Just need a block or 2.... a couple of tire tools a vice grip a rag and a air hose... I can change a tire in about 5 minutes this way...
  10. Hayabusa55
    26
    18
    Dec 17, 2012
    I helped him out. We jacked up the truck and used some breaker bars to take the tire off. Slipped the new one and set the bead. Filled it up and sat it down. Took about 20 minutes cause his bead tool kept blowing out of the rim lol
  11. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    In a pinch... bead setting with starting fluid.
