Cleaning injectors
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Dec 25, 2016.
Howes
spyder7723 and bigguns Thank this.
5 gal of gas in the tank
Overdose of Bowes mpc works great. Or a couple of cans of seafoam
Cummins injector flush...if it's still around. Used to be 1.25 gallons, came in a box with a plastic bladder. Hook up supply & return lines straight to the engine and let it idle until empty....this stuff works good!
Do not use most of that crap if you have a emissions engine , it can destroy very costly parts in the DPF and DOC.
Use a specific injector cleaner chemical that is approved.
spyder7723 and tony97905 Thank this.
ATF for a mechanical engine.
Power Source for electronic engine.
