Clutch Problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by cwaldo, Nov 4, 2017.
  1. cwaldo
    cwaldo Bobtail Member
    6
    2012 cascadia bd7612 eaton fuller 10 speed
    just installed my second clutch with the same out come problem. we installed a eaton fuller solo hydylc clutch. The old clutch had been worn down and had only 15% left no other problems.
    The 1st clutch was installed and less then a day i get a loud humming and vibration when i release the clutch and douncing from stand still start. the sound goes along the way you me be ridding the clutch and holding the break at the same time and slowly letting off the break and moving, bouceing and vibrating and bounce.
    the parts replaced
  3. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,792
    Jan 17, 2017
    I'd take it back to the place where it was serviced and explain the symptoms. If it's not running right, then they either need to do more work, or they did something wrong.
    Grubby, bigguns and Bean Jr. Thank this.
  4. cwaldo
    6
    thank you they have it and have no clue whats wrong
  5. 201
    201 Road Train Member
    12,642
    25,976
    Apr 16, 2014
    high plains colorado
    Sounds to me like you didn't have the flywheel resurfaced or replaced. Flywheel is warped.
    Grubby Thanks this.
  6. cwaldo
    6
    had it resufaced also
  7. MACK E-6
    49,777
    235,375
    Could someone have told you it was done when it actually wasn't? Sounds like a visit to a second shop is in order...
    Grubby Thanks this.
  8. 201
    12,642
    25,976
    Apr 16, 2014
    Ok, well, I've had clutches that may have had a little oil or even a sticker that wasn't removed from the disc. Freightliner's ( and International's) are notorious for rough engagement. Pete and KW are like butter compared to a Freightliner, not sure why that is. I drove a Freightliner cabover, that there was absolutely no friction point. It was either in or out, like a dog clutch. The truck would jump like a rock star. Trying to back in somewhere with that truck was no fun.
    Grubby and bzinger Thank this.
  9. Heavyd
    Heavyd Road Train Member
    7,812
    6,265
    Feb 4, 2009
    For future reference, you can take out a Solo and put in a regular style adjustable clutch.
    As for your problem, did you remove the flywheel and resurface it?
    SAR and Grubby Thank this.
  10. jbatmick
    jbatmick Road Train Member
    2,199
    2,507
    Dec 1, 2009
    hastings, Fl
    New or re-built clutch ?
    I quit using re-man ones, had a few problems there.
    What rating clutch ?
    Possible you need a higher capacity clutch.
    And do check the re-surfacing .
  11. 201
    12,642
    25,976
    Apr 16, 2014
    I went through 2 clutches on my Western Star, and I'm not a clutch abuser ( quite frankly, I rarely used it) both times, the springs in the disc broke. The 3rd time, I told them to stick these reman's where the sun doesn't shine. Guy said, well, you can go with a "springless" disc, it'a bit rougher engagement, but all the "extreme duty" trucks use them. I said, lay it on me brother, why didn't you tell me about that 2 clutches ago. I suppose they wanted to make some money 1st. Never had a problem again.
    Grubby, bigguns, bzinger and 2 others Thank this.
