Cold and setting trailer brakes
Discussion in 'Questions From New Drivers' started by Buckeye 'bedder, Feb 1, 2011.
  1. Buckeye 'bedder
    Buckeye 'bedder Road Train Member
    1,043
    440
    Sep 26, 2010
    Nowhere
    Okay,so I do not set the trailer brakes when they are wet and the temps are freezing or below, right? I am sure I'll learn this at school, but what to do when dropping a trailer during freezing temperatures? I set the trailer brakes, uncouple the lines, put down the landing gear, unhook, and pull away. So the trailer is sitting with its brakes on (I would assume the brakes have to remain set, especially if I can't give up or don't have chocks?). Won't the brakes freeze and give the next driver fits trying to free them? Just like to know ahead of school.
  3. chompi
    chompi Road Train Member
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    Yep, sometimes they do. Usually you can drag them for a second or two and they break loose. It help if the trailer is loaded though. I never set my trailer breaks year round, unless on a really steep incline or a dock that requires it. If you set your parking break you already have ten wheels locked down. That should be plenty. You can use a wheel chock too in the winter if necessary.
    BNR32 and rocknroll nik Thank this.
  4. rocknroll nik
    rocknroll nik High Risk Load Member
    4,490
    5,770
    Oct 18, 2008
    can't read the sign
    Yeah probably, but unfortunately that's how it goes.....hopefully the weather will warm up enough....or the driver will have to get out the BFH and give the brakes a tap or two to bust them loose......that is if they don't break lose on the first tug or two
  5. 123456
    123456 Road Train Member
    10,555
    5,746
    Oct 22, 2010
    32179
    You may only have 4 wheels locked when setting tractor brakes !!!!!!!
    25(2)+2, Bucktrucker and scottied67 Thank this.
  6. Buckeye 'bedder
    1,043
    440
    Sep 26, 2010
    Nowhere
    10 wheels, on a loan trailer sitting at a yard, dock, etc.?
  7. celticwolf
    celticwolf Road Train Member
    1,527
    642
    Oct 10, 2010
    Kittrell, NC
    I only got 6 on my tractor.. Super singles.. :) right now only 4 on the trailer.. I an a 10 wheeler. Hahaha
  8. Flying Dutchman
    Flying Dutchman Road Train Member
    1,274
    522
    Nov 2, 2009
    Northern California
    I used to only set the truck brakes. Unless I was done for the night...then both knobs out. Never dealt in sub freezing temps out there tho, we're spoiled in central Ca
  9. scottied67
    scottied67 Road Train Member
    10,823
    12,639
    Mar 14, 2010
    california norte
    Typically only 1 axle on the tractor has the spring parking brakes.
    If you're needing to drop the trailer in those conditions, ride the brakes for about a mile before the drop to warm them up and dry them out before you drop so less likely to freeze up.
    123456 and Buckeye 'bedder Thank this.
  10. 25(2)+2
    18,750
    45,491
    Sep 18, 2006
    the road less travelled
    Most tractors only have spring brakes on 1 axle, never on the front and seldom on both drives.That's 4 wheels. Some tractors don't have enough brake to hold the tractor alone on an incline, let alone, keep a loaded trailer from rolling.
    If you have been running in winter storm conditions, the shoes and drums get warm enough to melt that heavy dusting of snow on everything and freeze them even though they aren't set.
    The best way is to stay in the seat long enough to cool them down while periodically moving it so it doesn't get stuck by melt refreezing.
    Other than that, get the big pry bar, and big hammer, and maybe even a torch; I carry all 3. Sometimes the trailer you hook to is frozen before you ever see it.
    Lonesome and 123456 Thank this.
  11. groundpounder
    groundpounder Road Train Member
    2,569
    1,039
    Nov 13, 2009
    Being out of upstate NY unless the roads are bone dry I never set the trailer brakes in the winter when its below freezing unless I'm dropping the trailer...
    or if you have to set them in the winter and your unsure about them freezing drag the trailer brake a little with the trolley just don't go crazy and smoke them !!
    Flying Dutchman Thanks this.
