Constantly Over weight
Discussion in 'Ask An Owner Operator' started by bonder45, Jun 29, 2020.
  1. bonder45
    bonder45 Road Train Member
    1,775
    5,315
    Oct 2, 2011
    Williston, ND
    To start off the load is never on the truck for more than 40 minutes and it’s not being driven on public roads.
    The truck is a International pro star with 13k front and 46k rear tandem dual drive axel.
    All my loads scale the back 2 axels at 49,000lbs.....
    How bad is this for the truck given the short load times ?
  3. Doealex
    Doealex Medium Load Member
    597
    1,131
    Feb 21, 2018
    Not as bad on the truck as it’s on trailer axels parts and tires.
    Coffey and bryan21384 Thank this.
  4. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,784
    Jan 17, 2017
    Private roads tend to be a bit bumpier than public roads. If you are running overweight and bouncing a lot, you might greatly accelerate wear on suspension parts and tires.
    That said, you might run it for years that way with no problem, but you might pop a spring in a pothole tomorrow.
    Tb0n3, Coffey and Midwest Trucker Thank this.
  5. adayrider
    adayrider Road Train Member
    1,289
    1,732
    May 7, 2018
    Truck will be fine, slow down and take it easy on the truck.
    Farmerbob1, Coffey and feldsforever Thank this.
  6. uncleal13
    uncleal13 Road Train Member
    3,757
    6,199
    Apr 9, 2009
    Humboldt, Sk
    46,000 lbs rears, almost within spec.
    Farmerbob1 Thanks this.
  7. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,039
    Nov 18, 2014
    Land of local
    Exactly what those 46s were built for. I'd worry more about being smooth on shifts.
    Farmerbob1 and Coffey Thank this.
  8. bonder45
    1,775
    5,315
    Oct 2, 2011
    Williston, ND
    80% of the roads I drive on are paved and the other 20% I’m usually going turtle slow anywho!
    Well this calms my anxiety a bit down from taking bigger loads.
  9. Doealex
    597
    1,131
    Feb 21, 2018
  10. Doealex
    597
    1,131
    Feb 21, 2018
    Good catch!;)
    Farmerbob1 and Diamond Reo Thank this.
