Why do you suppose a shipper (who uses temp recorder) wants a "jarred fresh soup" product be shipped at 32 degrees F continuous, cross-country? I get the fact continuous prevents hot and cold spots, and is especially useful for produce and to quickly and evenly change a load's temp
This is for Kroger and I assume is soups they must sell in the deli department since it's shipped cold. The load contains a dozen different types of soup. Some are dairy based, some are vegetable based, some are meat based, and some are seafood based, and everything in between.
I just can't see the need for continuous, and the 32 degrees F seems strange too. But, I run it the way the bills and shipper says.
Any ideas why they may have chosen to run all of their loads like this? Some un-practical quality control guru set the demands years ago in the beginning, and it just stuck?
Mini rant over
Continuous Loads - Really?
Discussion in 'Refrigerated Trucking Forum' started by STexan, Jan 30, 2016.
Because they can
Never hauled soup that needed to stay at 32 ... but I'd run it continuous anyway it sounds like they want it just on the edge of freezing but not actually solid .. if you put it on cycle you might risk freezing some ...
Most shippers just put continuous on everything. You learn what you can get away with for cycle ... Basicly any leafy greens or any type of berry must be continuous .. your apples onions potatoes carrots etc. that are heartier have a wider temp range and they will be just fine ..Dominick253 Thanks this. -
I wouldn't think this time of year it would burn anymore fuel? even on continuous.
Nothing burns fuel like a -10 load in hot summer heat..MachoCyclone, Dominick253 and TGUNKEL Thank this. -
In some ways, most units seems to run "quieter" on continuous (unless it's a Carrier and needs to supply heat) as it runs at a lower RPM's 90% of the time and there's not the bone jarring starts all night long. I don't mind, but it does rack up some serious hours and does burn fuel considerably faster but I guess that's my boss's problem.
Some shipping office guru probably thought a reefer shutting down might not start again... Just a guess.
Most of the loads I haul specify continuous, including prepared foods. I cycle when I can. Only took me a couple of rest breaks not to be woken up by the unit starting up or shutting down. -
I think thats it! (Problems if reefer dont start up again)Dominick253 Thanks this.
To keep it from freezing during the winter without worrying about heating it up. Nobody wants soup heated 20 times.
I be if you were to read the label, it says fresh never frozen, no preservatives...and that is the reason they need a very stable temperature of 32, and not 24 to 40.
I'm sure it is a "fresh, no-preservatives" product but today's refer trailers don't have that much of a swing once the product temp is stabilized. And no doubt the grocery storage cooler probably runs at 36-43 F where it will sit for probably a week before the stock is replaced with fresh.Dominick253 Thanks this.
