What are the physical agility tests like in Joplin?
I read here in one of the threads they make you lift 50lbs in various ways including over your head. I am female and afraid I wouldn't be able to do it. Can someone give me details on this test? Does what they have you lift have handles, etc?
Conway physical agility tests (Joplin)
Discussion in 'Con-Way' started by DedicatedDriver, Oct 7, 2012.
You have to lift a 30lb duffel over your head and carry 50lbs in a crate that has a handle. Don't worry yourself about it. If you're not sure if you can do it go to walmart and lift some dog food bags. Mostly they're checking to see that your heart rate doesn't get too high while doing things similar to what you'd do in your job.
Its not hard....quite easy....dont stress over its nothin.
DedicatedDriver Thanks this. -
They are checkin your heart rate take deep breath as your doing it all and you will be good.
Thanks guys... I talked to a recruiter today and she said you do not have to lift 50lbs over your head, just 30, and they've put a lot of tiny women thru the school so thanks for the advice..
No problem. Just remember to breathe while you're doing the lifting. Holding your breath will spike your heart rate. Otherwise it's easy.
I guess they are making sure you can work on the docks before they let you drive.
Is there a requirement to "duck walk" under the trailer to pass the company physical? I am very interested in driving for Con-way. I am 6'7" tall, and duck walking under a trailer may be very difficult at my height. I can crawl with no problem though.
