Coolant depleted without any visible leaks
Discussion in 'Questions From New Drivers' started by DAX_, Jul 15, 2021.
  1. DAX_
    DAX_ Medium Load Member
    603
    502
    Sep 4, 2017
    Long story short that's what happened
    Took it to the company shop to get it looked at
    They said they pressured tested it and found nothing wrong with it and the coolant remained topped off
    Could there have been any other reason the coolant depleted or did the shop just didn't do anything
  3. skallagrime
    skallagrime Road Train Member
    3,856
    9,943
    Apr 10, 2012
    Indiana
    Replace your cap, they use a pressure testing cap not your cap, so that seems to be the point of failure
  4. Redtwin
    Redtwin Road Train Member
    5,488
    7,608
    Aug 17, 2012
    PBC, FL
    I had a coolant leak that left no visible puddle on ground etc. Just constantly got low coolant messages. Reported it to shop they did pressure test and found nothing. Ran like that for thousands of miles, just kept filling it up every couple days. It wasn't until the leak got bad enough to leave streaks on the engine block that they narrowed it down to the water pump. This was a Cummins which has a red painted engine and of course the coolant is red in color so that didn't help spotting the leak.
  5. Frank Speak
    Frank Speak Road Train Member
    4,521
    13,825
    May 3, 2016
    A bad EGR valve will gulp down coolant.
  6. DAX_
    603
    502
    Sep 4, 2017
    So they can't discover this doing a pressure test?
    Rideandrepair Thanks this.
  7. Moose1958
    Moose1958 Road Train Member
    15,180
    33,432
    Dec 17, 2010
    Williesburg, Virignia
    I have tried for several minutes to remember the models, but Navistar had a problem with their auto-shift transmissions sucking water out of the truck. It was fixed and most of those old tractors are off the road now. I know for a fact that USA-Truck had an issue with some of their first Prostars.
  8. DAX_
    603
    502
    Sep 4, 2017
    If I take it to freightliner and tell them that they already tested it will they actually look for the real problem..or will I have to just keep driving until I'm stranded basically
    No Exit and Rideandrepair Thank this.
  9. Frank Speak
    4,521
    13,825
    May 3, 2016
    I don’t know. I just know if it’s disappearing it could be the EGR valve
  10. Flat Earth Trucker
    4,142
    15,546
    Nov 19, 2018
    TravR1, Dave_in_AZ, No Exit and 4 others Thank this.
  11. Redtwin
    5,488
    7,608
    Aug 17, 2012
    PBC, FL
    I just kept a few gallons of coolant on the truck and kept filling it up so I could keep rolling. I already had it on record that I reported the issue to the company shop who then returned the truck back to me with no fault found. Not much more I could do then other than refuse to drive the truck which in my mind and would just create a whole new set of problems that would only cost me money in downtime or looking for another job.
    I even paid for some of the coolant out of pocket rather than submit excessive receipt reimbursements that might cause the company shop to have me take it to the dealer. The money I spent on coolant would be miniscule compared to lost revenue sitting in a hotel for days only for the possibility of the dealer also telling me they couldn't find a leak.
