Hello all! I have a new issue that has developed on my t600. The cruise control has decided to quit controlling the speed, idle control works though. If I hit “set” the truck will just go to an idle...no cruise and the foot throttle seems to be deactivated. If I turn the cruise off it all comes back to life and runs fine. I’m a little puzzled with this. Engine is a Cummins N14 celect. No check engine light and idle control and jakes all work so I don’t think it’s a clutch or brake switch.
Cruise control not working on 96 Kenworth T600
Discussion in 'Kenworth Forum' started by Xzachtly, Feb 10, 2018.
Sounds like issue with Vehicle Speed Sensor or wiring to ECM.
pushbroom Thanks this. -
Had an N-14 in a T2000 that used to do this occasionally - it’d get ‘tripped up’, but toggling the cruise on and off reset it.
Could try swapping out the cruise switch to eliminate, or VSS as said -
Post the fix if you get it!ShooterK2 Thanks this. -
Thanks for the help! The vss is a 4 wire sensor that splits to two connectors, a guy here suggested I try swapping the two halves to see if signal that was working for the speedometer would allow the cruise to work; the truck wouldn’t crank over as soon as I did that. Still searching...I’ll keep you posted!
Update: finally got it working again! Ended up being a broken wire in the harness going to the run. Thank you all for your help!
blairandgretchen Thanks this.
