Cubed trailer
Discussion in 'LTL and Local Delivery Trucking Forum' started by Cajuntex, Apr 15, 2016.
  1. Cajuntex
    Cajuntex Light Load Member
    76
    Feb 6, 2015
    how do drivers get there first load off when you don't have a dock.
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Put hand pallet jack in trl and wheel them to the back so fork truck can grab it.
  4. Bob Dobalina
    Bob Dobalina Road Train Member
    2,578
    4,456
    Sep 20, 2015
    The "Buckeye"
    Verrry carefully.
    Mike2633 and Dominick253 Thank this.
  5. Cajuntex
    76
    Feb 6, 2015
    Seriously how do you get boxes off when there is no room at the back of trailer. No forklift just driver and a ramp.
  6. truck_guy
    truck_guy Medium Load Member
    376
    440
    Oct 30, 2015
    SE MI
    If you're talking food service, you pretty much gotta set your ramp up and start carrying or tossing cases down. We don't work out of the back, but sometimes the side doors are stuffed to the edge. Our loaders are not supposed to stack it so high that the first few cases can't be reached from the ground, and they're usually pretty good about that. Once I make enough room to push my cart up there, I start making reasonable stacks and go down the ramp backwards until I have enough room to turn around.
    Mike2633 Thanks this.
  7. Sho Nuff
    Sho Nuff Road Train Member
    1,175
    1,401
    Apr 9, 2015
    Do you at least have a pallet jack? A lot of times you just have to break down the pallet to lighten the load, and then pull it out. I had to do many times when I did straight truck residentials.
  8. Bob Dobalina
    2,578
    4,456
    Sep 20, 2015
    The "Buckeye"
    @Mike2633 might be able to answer this one. Do they ever max you out like that, Mike?
  9. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    High reverse gear and service brakes. Unloads them every time if you have the doors open.
    kuggie101 and speedyk Thank this.
  10. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    If u talking food guys, it's with a dolly. Or 2 wheeler whatever u wanna call it.
