40000 miles after changing main bearings truck started to consume a lot of oil. It used to be 1.5-2 gallons between oil change and now is 5-6 gallons. There is a small leak from the head , however no oil on the ground at all
Any advise will be greatly appreciated
Cummins ISX 475 with 980000 miles is using a lot of oil......
Discussion in 'Trucks [ Eighteen Wheelers ]' started by snejana73, Dec 17, 2016.
Page 1 of 3
sounds like its wore out
What do you mean ? What is wore out?
4-5 gallons between oil changes? I'd just stop changing the oil and swap filters every 15-20k.
Piston rings or turbo or valve seals...
Time for an overhaul before it spits a rod out the side of the block.
We just put a cummins recon in our at 780,000 kms
Could be front seal leaking
If it was front main seal he would see it leakon the ground...
980,000 miles and your wondering why its using oil now????
Its done. Time for an inframe or with that kind milage a recon engine wouldnt be a bad choice either.
Around thses parts guys with isx are only getting about 5-6 hundred thousand out those engines. Start useing oil or spit a con rod.
Id say you did fantastic.!GMB Thanks this.
Page 1 of 3
