Cummins N14 Celect 460 to 500hp
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Dec 6, 2023.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,230
    1,635
    Dec 4, 2019
    My CPL is 1580. Injectors, turbo, different ECM or ECM flash, different pistons? Fixing to tear this engine down and rebuild.
  3. OLDSKOOLERnWV
    18,359
    276,328
    I’m not to where I can look at my CPL book right now, but should be home tomorrow night. Do you have a certain CPL # you plan on building the engine to…?
    Bean Jr. Thanks this.
  4. mile marker 27
    1,230
    1,635
    Dec 4, 2019
    I’m assuming the 460hp is the tallest horsepower in the Celect, line up? I do not have an idea what CPL in Celect + would be the easiest to go to, north of 460hp. My thought are, I’m gonna do new injectors, turbo, freshen or replace ECM and in frame. So,……… what can I achieve up to 525hp?
  5. mile marker 27
    1,230
    1,635
    Dec 4, 2019
    Is there a pdf that will list part numbers for my current CPL 1580, so I can compare it to a 500-525hp C+ CPL? If my 1580 is 460hp, seems to me there ought to be a few things(injectors, turbo, ECM flash) so that essentially this 460 could be “turned up”, 10-15%?? That would have it in that 500-525hp.
  6. DUNE-T
    DUNE-T Road Train Member
    6,944
    16,849
    May 10, 2015
    Detroit, MI
    You gotta go to Genuine Cummins Parts
    Enter your serial number and it will show you all the parts you have.
    Do the same thing in a different browser window with a serial number of an engine with 2592 cpl, then compare
    mile marker 27 Thanks this.
  7. DUNE-T
    6,944
    16,849
    May 10, 2015
    Detroit, MI
    You gotta go all the way up to 525/1850, with 500/1650 you won't feel much difference
  8. mile marker 27
    1,230
    1,635
    Dec 4, 2019
    Those are both Celect + CPL’s, correct? Were there any Celect CPL’s with higher HP, than 460?
  9. DUNE-T
    6,944
    16,849
    May 10, 2015
    Detroit, MI
    As far as I know, yes, 460 max for Celect, but you can make it a Celect plus. I believe you will need a new harness and a barometric sensor, plus the ecm programming.
    You can join the N14 group on Facebook, lots of knowledgeable people there
  10. mile marker 27
    1,230
    1,635
    Dec 4, 2019
    So, there’s nothing mechanically that can be done to achieve +460hp and there’s nothing really, outside of changing the ECM to a +, to gain anything either?
    I guess this why I like the old mechanical engines best. I really wish I could just convert this truck to a mechanical engine.
