Cxu613 mp8 rust on cam and rockers and pushing coolant
Discussion in 'Mack Forum' started by Edjahman, Jun 16, 2020.
  1. Edjahman
    Edjahman Medium Load Member
    648
    444
    Apr 2, 2013
    So I just had the valve covers pulled to have the overhead adjusted and mack said that the camshaft and the rockers have rust.
    They also said that it saw signs of pushing coolant but I don't know what that means.
    What causes this?
    Thank you
  3. Judge
    89,711
    Getting water/antifreeze up there, probably a head gasket.
    Worse would be a cracked head.
    Edjahman Thanks this.
  4. Deere hunter
    2,118
    9,986
    Aug 5, 2017
    Shallowater Texas
    Antifreeze will not cause rust internally especially with the oil mixture. I can’t believe somebody was running straight water but very puzzling. When truck is running get half full bottle of water put the radiator tube down in see if you see air bubbles.
  5. Edjahman
    648
    444
    Apr 2, 2013
    I'm going to look at it in a while. Mack told me that the rockers are so rusty that they have to be replaced and the cam too.
    They are talking 18K $$$
    Whats this pushing coolant mean?
    I believe they were referring to the injectors.
    Thank you
  6. Deere hunter
    2,118
    9,986
    Aug 5, 2017
    Shallowater Texas
    They just mean it’s pushing coolant into your oil and that could come from the bottom of liner packs head gasket cracked head yes also I think A Mack can push it through the injectors that would be the easiest fix.
  7. Edjahman
    648
    444
    Apr 2, 2013
    Thank you
  8. Frontman
    Frontman Light Load Member
    166
    151
    Apr 4, 2012
    Is this the ...2016 Mack with 300K miles?
  9. Edjahman
    648
    444
    Apr 2, 2013
    Yeah. Mack is saying the rust in the overhead is from sitting for a long time.
    They also said that they wanted to pull the injectors because it might need cups.
    I wonder if Peterbilt paid for the repairs would it still be a usable unit?
    I'm already 5K into it because of regular maintenance items
    Obviously I should have had the overhead looked at first so my bad on that one.
    Thanks
  10. Frontman
    166
    151
    Apr 4, 2012
    So, you found all these problems before you even drove the truck off there lot?
  11. Edjahman
    648
    444
    Apr 2, 2013
    I drove it to the Mack dealer to have it serviced and evaluated.
    So I drove it a few miles.
