DD60 Refusing to start, fuel entry issues.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by DetroitS60, Jan 23, 2021.
  1. DetroitS60
    DetroitS60 Bobtail Member
    28
    12
    May 12, 2020
    Hello,
    So I have a truck that's been giving me non-stop fuel problems. The main issue is that the engine stalls out if the truck has been sitting for an extended period of time because fuel is running out in the primary fuel filter, despite the truck having a ton of fuel. I keep getting told there is air in the system but I'm not sure how to suck the air out or prime the engine without using ether, as I already used a lot the previous year. Any ideas?
  3. blairandgretchen
    13,803
    75,380
    Dec 9, 2011
    South west Missouri
    Check valve - behind the ECM?
    p608, Rideandrepair and cke Thank this.
  4. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    There is a check valve in the fuel return, on line from back of head.
    Something is letting fuel siphon back into tanks.
    Try turning off the valve by the fuel filter as soon as you shut it off, see if it helped,
    The check valve is less than $100, I would change it, very simple if you can reach it.
  5. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    There is also a check valve at the inlet of the Davco filter housing that can be problematic if it has that set up?
  6. Rideandrepair
    17,484
    56,704
    Aug 8, 2015
    Never heard of that.
    Bean Jr. and blairandgretchen Thank this.
  7. blairandgretchen
    13,803
    75,380
    Dec 9, 2011
    South west Missouri
    Sorry - am I thinking of N14.
    S60 is at the back of the head?
    I best just see myself out. I’m trying to remember all the issues my buddy had between a S60 and N14 fuel issues with neglected tore up trucks!
    Rideandrepair Thanks this.
  8. Rideandrepair
    17,484
    56,704
    Aug 8, 2015
    Old man posted a diagram. As far as I know, the fuel pump has on built in. Might be one on the fuel tank shutoff valve, but I think it’s more of an equalizer valve.
  9. Rideandrepair
    17,484
    56,704
    Aug 8, 2015
    The only way I know of, to check for sucking air, is to pressurize tanks, and check lines for leaking. I need to do mine, since I have tell tale bubbles in tanks. They also use temporary clear hoses to see air in lines, under operation. I’ve never done either. But suspect My shutoff valve is sucking air.
