Def fuel light and check engine light on 2011 Kenworth
Discussion in 'Kenworth Forum' started by new trucker2017, Aug 16, 2017.
  1. new trucker2017
    new trucker2017 Bobtail Member
    Def fuel light came on along with check engine light. 2011 Kenworth t660. Filled def fuel tank & lights still on truck will only go 5mph. Any help would be greatly apreciated.
  3. mitmaks
    mitmaks Road Train Member
    2,557
    2,072
    May 16, 2014
    Did you run low on DEF fluid?
  4. ZVar
    ZVar Road Train Member
    10,911
    23,827
    Sep 10, 2010
    Flint, MI
    Is this a real question?
    Do a parked regen then take it to the shop to get hooked to a computer to see whats wrong.
  5. fargonaz
    fargonaz Road Train Member
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    DEF generally doesn't have anything to do with DPF regen. There are separate indicators for DPF.
    What engine? How much DEF did it take?
    I'd look for obvious frayed wires and corroded electrical connectors in the DEF system.
  6. ZVar
    10,911
    23,827
    Sep 10, 2010
    Flint, MI
    Well the two times I've been in a derated truck they both were dpf needed cleaning.
    In both cases they were freightliners and in both cases the def light by the fuel gauge came on with one of the amber check engine lights.
    Both times I did a parked regen and that allowed me to get within 5 miles of the yard before derating again.
    Point though, is that dash lights don't tell you anything really. The truck needs to be hooked to a computer to find why it's derated.
  7. new trucker2017
    Yes ran low and had to go for miles to fill up
  8. new trucker2017
    3 gallons topped it off. The truck is now Drated and will be hooked to a computer tomorrow to know further.
  9. fargonaz
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    Most DEF tanks hold at least 15 gallons.
  10. shogun
    shogun Road Train Member
    6,075
    72,159
    Jan 23, 2009
    Doing a regen
    I would unplug the speed sensor and get back rolling. Also, the hose may have gotten pinched and the def tank thought it was empty and deranged. Same thing happened to a cascadia of ours two weeks ago.
  11. shogun
    6,075
    72,159
    Jan 23, 2009
    Doing a regen
    Derated not deranged.
    fargonaz Thanks this.
