Detroit 12.7L Turbo Sporadic/intermittent Working-Not Working
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ljesko13, Jun 26, 2023.
  1. ljesko13
    ljesko13 Bobtail Member
    39
    23
    Aug 30, 2021
    Hi all, I’m having issues diagnosing a turbo problem with my 1999 Detroit Series 60 12.7L engine. Here’s the full backstory:
    Every time the truck drives through a bigger puddle of water on the drivers side, something gets wet, and the truck just shuts off. Another issue that occurs with that is that the cruise control won’t work, not while trying to drive to pull it off the road or while stationary. Truck will re-start, but cruise won’t wo I and it’ll shut off after 20-30 sec. Once the truck dries off (I’m assuming that’s the reason), it works just fine, it typically takes 45 min to an hour of sitting it out. Here’s the kicker:
    About 4 months ago I ran through a bigger puddle, and after drying out, my turbo and a couple of gauges started acting up. Turbo randomly kicks in and out, sometimes to full power, sometimes it just stays below 15psi. It’ll happen instantly, like the engine gets jerked as the turbo kicks in and out. That lasted about 2 days, and afterwards I’ve never had an issue with it until 5 days ago. Now I’m having the same issue, but this time it doesn’t seem like it’s going away.
    Does anyone know what could possibly cause this, or where to look for? My assumption is either the ECM or some other harness is toasted, but I really don’t know too much to even look. All I know is that I have no power, and can barely go up the hill empty. Any help is highly appreciated.
  3. ljesko13
    39
    23
    Aug 30, 2021
    Here’s the link to the video. Sorry for bad quality but I can only replicate the issue while driving.
    Studio Project - Kapwing
  4. JB7
    JB7 Heavy Load Member
    792
    1,218
    Dec 13, 2022
    Laurel, MD
    "It’ll happen instantly, like the engine gets jerked as the turbo kicks in and out."
    Sounds like a turbo wastegate issue which can cause the problem you are having. Should also check for codes.
    Rideandrepair and Bean Jr. Thank this.
  5. blairandgretchen
    13,377
    71,914
    Dec 9, 2011
    South west Missouri
    Post pictures of the wiring harness out of the ECM please.
    Rideandrepair Thanks this.
  6. benjamin260_6
    benjamin260_6 Medium Load Member
    433
    484
    Aug 8, 2012
    Ontario, Canada
    Clean all your electrical connections. Batteries, starter, all your grounds, etc. Don't be afraid to add a few extra grounds. Your issue with the turbo is fuel related. If the engine doesn't get fuel, it can't build boost.
    Rideandrepair and wore out Thank this.
  7. Rideandrepair
    17,337
    56,256
    Aug 8, 2015
    Have you checked for codes? CEL flashes red when active. Yellow when stored ( old or intermittent ).
