Different ratios difference at 78 miles per hour MPG
Discussion in 'Ask An Owner Operator' started by Mid-May Trucker, Feb 20, 2020.
Thread Status:
Not open for further replies.
  1. Mid-May Trucker
    Mid-May Trucker Road Train Member
    1,118
    2,079
    Oct 23, 2018
    What difference lower Gear ratio make?
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    At that speed I don't worry about it. You already have a adequate ratio to get near 80 with that 13 speed.
    In my experience 13's were not particularly fast however if you can get up and shamble down the interstate at that speed with one it's plenty good.
  4. PE_T
    PE_T Road Train Member
    Why 78mph? You’ll have other bigger problems driving at that speed.
  5. Mid-May Trucker
    1,118
    2,079
    Oct 23, 2018
    If I buy truck I got to haul no matter the cost what are other problems.
  6. PE_T
    • Tickets/violations/CSA points
    • Higher chance of an accident (frequent lane changes, less following distance, less distance/time to stop, etc.) Higher insurance costs.
    • Higher fuel expense. Fuel is usually the highest expense in a trucking business.
    • More wear and tear on entire equipment: engine life, tires, leaf springs, air bags, shocks, torque rods, more frequent alignment, increased hose/wire chafing, and so on.
    • Many semi tires have a max speed rating of 75 or 72.
    Long FLD and npok Thank this.
  7. 062
    062 Road Train Member
    6,333
    33,973
    Oct 20, 2013
    Are the 10 and 13 od trans or is one a direct drive?
  8. brsims
    brsims Road Train Member
    5,296
    6,522
    Aug 8, 2009
    Meadville, PA
    And most steer tires are only rated for about 70mph....so there's that as well.
    Look around when you are driving. Most independents and O/O's are driving for fuel mileage, not speed. More money going out the exhaust pipe means less money in your pocket.
    PE_T and npok Thank this.
  9. Mid-May Trucker
    1,118
    2,079
    Oct 23, 2018
    the road 75 limits already said what the ever the cost and accidents are driver fault
  10. blairandgretchen
    13,964
    76,790
    Dec 9, 2011
    South west Missouri
    All depends on final ratio of transmission.
    Research the different transmissions.
    Why 78 mph? Faster you go, the bigger the mess.
    PE_T and jamespmack Thank this.
  11. Mid-May Trucker
    1,118
    2,079
    Oct 23, 2018
    Lots of people go 78 and don't crash and I can look at ratios all day but isn't doing anything cuz I need people that have those ratios and can give me MPG differences.
    alds and blairandgretchen Thank this.
  • Thread Status:
