different type of trailers
Discussion in 'Questions From New Drivers' started by jgarciajr40, Sep 15, 2017.
  1. jgarciajr40
    jgarciajr40 Medium Load Member
    650
    941
    Jun 18, 2016
    Just curious what advantages/disadvantages do "roll up" trailer doors have over the traditional "swing out" trailer doors. Just curious since every single company I've worked for has only had the "roll up" trailers.
    Also how about those trailer with side doors; I typically see furniture companies using them(53 ft trailers).
  3. Redtwin
    Redtwin Road Train Member
    5,485
    7,604
    Aug 17, 2012
    PBC, FL
    Roll up door reefers allow you to back up to the dock with the door closed. This helps maintain temp as the swing door reefers need to opened before backing up to most docks. The wide open doors will cause a temp change especially if the driver takes a long time to hit the dock properly.
    The disadvantage of a roll up reefer is the door uses some of the trailer headroom so really tall freight might not fit. The width is also compromised.
  4. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,982
    18,764
    Mar 9, 2014
    In a van down by the River.
    Less likely to damage them at warehouses cause aint got to worry bout tearing a door off.
  5. Driver0000
    Driver0000 Medium Load Member
    304
    320
    Jun 26, 2016
    Roll up doors are awesome in the rain and winter weather. Open on the dock.
    Trls with roll ups are not as wide/ tall as swing door trailers. - less freight.
    Backing with a roll up= more room and easier to see the dock.
  6. ZVar
    ZVar Road Train Member
    10,911
    23,827
    Sep 10, 2010
    Flint, MI
    I wonder if that is why most ltl's prefer rollups. Saves money on road calls to reattach doors in those tiny lots they tend to live in. :)
  7. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Also - Roll up doors allow for seal and lock control (security) at the dock level, as opposed to losing security once the trailer is pulled out by whoever, and before closing doors and [possbily] following secure protocols
    Rolls up doors require much more maintenance for proper operation and are considered an additional hazard potential when raising/closing from the ground.
  8. Lonesome
    Lonesome Mr. Sarcasm
    11,150
    22,851
    Dec 15, 2007
    Northern Indiana
    Try opening a roll up, when some of the freight ends up jammed against it. Or a spring, or roller breaks.
  9. Redtwin
    5,485
    7,604
    Aug 17, 2012
    PBC, FL
    Yeah, it's not as easy as a swing door where the shifted freight lands on your head.
    Lonesome Thanks this.
  10. m16ty
    m16ty Road Train Member
    2,267
    4,948
    Jan 22, 2016
    Swinging doors are much simpler, less stuff the tear up. I've tried to open a roll up with a broken spring, you'd be surprised at how heavy they are without the spring to help. Another bad thing about roll ups is forklift operators like to hit the track or the top of the door and tear things up. They are nicer to operate though.
