Do fuel tanks cross feed and equalize?
Discussion in 'Experienced Truckers' Advice' started by JC1971, Apr 1, 2022.
  1. Judge
    94,282
    Ohh cmon, we know you broke it off... let’s us in... How’d you break the nozzle off...
    But yes, equalization will happen.
    If fuel is super high I get one tank or say 50-75 gallon to get to a place to get it a bit cheaper.
    Rideandrepair Thanks this.
  3. Val_Caldera
    Val_Caldera Road Train Member
    2,569
    7,939
    Apr 2, 2021
    TARHEEL
    It May Equalize....as stated above.....unless the crossover Line is SHUT OFF.....IF It HAS A crossover Line.
    Some Trucks Do Not For Whatever Reason.
    Oh, and Fuel Gauge Is Correct Twice: FULL & empty.
    Some of the Remaining Older Truck Stops Have LONG HOSES.
    MadScientist and Rideandrepair Thank this.
  4. Val_Caldera
    2,569
    7,939
    Apr 2, 2021
    TARHEEL
    I Liked Seeing Road tractors Like the Picture. Even More Hilarious On SIGHT SIDE!!
  5. Tom Hank’s Volleyball
    Tom Hank’s Volleyball Light Load Member
    63
    141
    Oct 23, 2021
    Literally: “this bisch empty. YEET”
  6. tscottme
    tscottme Road Train Member
    Your truck will stop running when either fuel tank runs dry. That's to say you stop when the first tank is empty.
    JC1971 and Rideandrepair Thank this.
  7. pete781693
    pete781693 Road Train Member
    1,196
    8,988
    Oct 23, 2010
    My ol truck drew from the driver side tank back when fuel lines ran side to side from the bottom of the tanks. I was off exploring back roads bypassing the POE in a state that I was not supposed to be in. Thankfully I made it back into Texas and was on some long straight roads with long sight distances and I was intermittently able to drive on the wrong side of the road for a long enough time to get most of my fuel to move over. I then stopped and shut the valve on the bottom of the passenger side tank. Needless to say, I never put myself in that position again.
    Hammer166, JC1971 and Rideandrepair Thank this.
  8. JC1971
    JC1971 Road Train Member
    2,688
    9,832
    Jul 29, 2013
    Southwestern U.S.
    Sorry to disappoint you. I put the nozzle in and I was trying to twist the hose around to get the nozzle to stay in so I could walk away to wash the windshield and it just broke off. I don't think I put that much pressure on it. They seem pretty cheaply made.
  9. Val_Caldera
    2,569
    7,939
    Apr 2, 2021
    TARHEEL
    I Used A Rubber Strap With 2 Hooks To "set" The Fuel Handle In The Tank Neck.
    Secure Method.
  10. MadScientist
    MadScientist Light Load Member
    103
    145
    Dec 14, 2019
    It all depends upon what truck, exactly, you're talking about. Not all are the same. But in most cases if you let one tank run dry without shutting it off your truck will start sucking air and will not run.
    Many trucks will equalize due to gravity, but not all will. Others will only equalize when the truck is running and the tank with less is getting more fuel via the return lines from the electronic fuel system than the other tank.
    It all depends on how the specific truck in question is set up.
    Rideandrepair and JC1971 Thank this.
  11. striker
    striker Road Train Member
    6,023
    6,442
    Aug 8, 2009
    Denver, Co
    My thoughts exactly, our older Mack's would equalize in a matter of minutes, whether running or not, these new KW's can take hours to equalize, and I've crossed my fingers a couple times
