Do you leave straps on the winches or take them off every time?
Discussion in 'Flatbed Trucking Forum' started by Kshaw0960, Apr 12, 2023.
Do you leave straps in the winches every time?
  1. Leave ‘em on winches
    20.3%
  2. Take ‘em off and roll em
    79.7%
  1. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,023
    Jun 17, 2018
    I’ve toyed with the idea of leaving straps in the winches and throwing hooks essentially, or throwing straps and always taking them off the winches. After a couple months I still cannot decide which is faster. What do y’all do?
  3. Mattflat362
    Mattflat362 Road Train Member
    2,705
    5,768
    Feb 18, 2015
    Avon Lake, Ohio
    Leave em on and replace them as needed...
  4. skallagrime
    skallagrime Road Train Member
    3,853
    9,925
    Apr 10, 2012
    Indiana
    Im in the take em off amd wrap every time, if you store straps under the bunk, more a wintertime thing, you will at least have not frozen straps to deal with, also i find tossing my 6-8 (most loads) straps far easier from rolled up
    roshea, cke, mitmaks and 5 others Thank this.
  5. jamespmack
    216,320
    Depends on the job. Use the a few times a week. Put them away. Three loads a day. Your gonna leave them on.
    PSM379, booley, CAXPT and 3 others Thank this.
  6. Kshaw0960
    1,581
    5,023
    Jun 17, 2018
    I find it near impossible to throw the hook end over freight and not get it twisted like a mfer on anything over 4ft tall. Only way is to roll the strap around the hook and it wastes so much time.
    Also toyed with the idea of having a separate set of straps that are like 16ft long instead of 30 so it’s much faster.
  7. D.Tibbitt
    152,898
    I always rolled them up ... Even running local stuff and doing 3+ loads a day . if u have a competant forklift driver . he can unload and you can roll up within the same timeframe.. And finish about the same time.. Just do it by hand is always the fastest way for me. ..
    roshea, PSM379, booley and 4 others Thank this.
  8. okiedokie
    okiedokie Road Train Member
    13,328
    103,696
    Jun 13, 2011
    PNWET
    Running a maxi 20170404_133253.jpg truck a strap roller comes in handy.
    Speed_Drums, booley, CAXPT and 2 others Thank this.
  9. Judge
    89,737
    I always rolled mine.
    a strap winder didn’t take but a second.
    But i held hook and throw strap.
    Some places get mad if you do it other way, you’ll hit some idiot walking by with the hook vs slapping in face with strap.
    Hook knocks them out cold too.
    roshea, RedRover, Sons Hero and 6 others Thank this.
  10. NoBigHurry
    NoBigHurry Light Load Member
    68
    98
    Jul 3, 2015
    I worked for two different flatbed companys were one required me to do it one way and the other required that I did it the other. I found I liked to take straps off the winches. I had a speed roller. I think it is easier to get the strap tighter when you feed the loose end into the winch after throwing. When you leave them on the winch you have to secure them so they dont come loose. They are subject to weather more including freezing and dirt. They are more likely to rub on tires especially if drop and hook trailers. Some freight is easier to unload when both ends are released. And it often did not take me any longer to strap and unstrap especially with company trailers were the winches had issues.
    roshea, CAXPT, beastr123 and 1 other person Thank this.
  11. jamespmack
    216,320
    All depends. I have a place that sends 3 illegals out on towmotors. They do a great job. Your not quick enough to get them off. Blow the straps, kick them under the trailer. Stand back. You can't wind them up on the winches fast enough. Now move, another truck is behind you. Go get you next load.
    cke, Mattflat362, CAXPT and 2 others Thank this.
